SOURCE: NO WATER COMING THROUGH ON DISHWASHER JUST LOUD BUZZING NOISE
Check the instruction manual, Smeg often use the program lights to give an error code.
You'll have to first ensure that the valve is open where the supply
gets its water from the sink supply, and water is getting to the
dishwasher. There is a garden hose type swivel adapter after the valve,
right? Close the valve tightly- even if it scrapes the wood - and then
unscrew that hose coupling and see if the hose is full of water. Look
there for a strainer inside the hose that is clogged. Clean it. If that
is good, reconnect and ensure it's tight.Open the valve. Now check the
dishwasher to see if it's getting water. Then at the point where the
hose enters the dishwasher is a spring loaded hose ring coupling,
right? If not, and there's another garden hose adapter, remove that
(after turning off the water again)and see if there's a strainer there.
If water is supplied to the dishwasher okay, then it is probably the
electric solenoid valve inside the base of the dishwasher.
The buzz that you hear is the water line solenoid. It probably is not opening up to let the water through. You should replace this solenoid and it will fix your problem as long as you have water coming up to the diswasher's solenoid valve.
SOURCE: loud clanking noise in dishwasher
Most likely the motor as food caught in the sump would not make a noise you described.
http://tclaundryrepair.com/home
SOURCE: HDA3400G020WW noise
dear sir the problem you have sounds like the solenoid that opens the drain actuater can be worn out open the bottom panel run tru a cycle observe when the solenoid open it may be that there is something causing the solenoid to buzz either worn out or a wire or something in the way causing not to close proprly thanks from gilles
SOURCE: My Ignis dishwasher ADL 348 is not dissolving the
My adl 348 is 3years old. Made strange noise and didnt really wash now it doesnt appear to be washing. What would it be and is it easy fixed?
The dishwasher is not filling with water...
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
