Tablets & eReaders Logo
Posted on Feb 14, 2013
Coby Kyros mid7033 stuck on Coby screen
After viewing a video I put the device to sleep. Turned it on the next day, and it will stay stuck on Coby screen. I tried the reset button, and Factory reset from recovery. Did not work.
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Dec 30, 2010
SOURCE: I CAN' T DOWNLOAD WITH
You will most likely need a driver so that your computer can recognize the device. Check the box that your Coby Kyros Tablet PC came in with and grab the Setup CD. It should have the driver inside the setup. If not you can download the driver (which may or may not be) at coby's official site show here
http://www.cobyusa.com/?p=prod&prod_num_id=10498&pcat_id=1013
Hope this helps : )
Anonymous
  • 739 Answers
  • Posted on Jan 22, 2011
SOURCE: Youtube videos won't play on my Coby Kyros.
Hi
you have to install adobe flash player into your Coby Kyros because youtube video requires flash player to work.
regards.
Anonymous
  • 76 Answers
  • Posted on Feb 28, 2011
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
iiiears
  • 14 Answers
  • Posted on Apr 08, 2011
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Anonymous
  • 1116 Answers
  • Posted on Aug 30, 2011
SOURCE: The screen in my Coby
You must contact Coby first. Here are the various ways to contact them:
Just got a MID8042 want to watch from portable hard drive, will this work? t
Amazon.com : Coby Kyros 8-Inch Android 4.0 4 GB 4:3 ...
www.amazon.com/Coby-Kyros-8.../B0075W8Y1S
Amazon.com, Inc.Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 Capacitive .... The Coby Kyros MID8042-4 Tablet is a powerful and flexible internet and .... Simply connectyour Coby Tablet to your HD TV with an HDMI Cable is the ticket to .... I bought the Coby 8042 as a low cost portable device I could take with my while traveling.
Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 ...
www.amazon.com/Coby...Internet-Tablet/.../B0093XT...
Amazon.com, Inc.
Rating: 3.1 - ‎1,377 reviews
Amazon.com : Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 ... SANOXY® PU Leather Carrying Case For 8 inch Tablet Stand w/ USB ... With sleek and stylish Coby tablets, you can relax and enjoy your favorite music, 1080P HD videos, ..... Picksup home wi-fi & mobile hotspot (wi-fi from my phone) just great, never ...Missing: mid8042
1helpful
Coby kyros mid 7015 stuck at logo screen how do i fix it
Take out the battery for at least 4 hours and just let it sit. Put it back in and it should be fine
2helpful
6helpful
Reset kyros mid7033
This is the solution for the MID7033 1. Turn on the tablet
2. When the COBY logo appears simultaneously press the (Power Button)+(Volume -)+(back Buttom).
3 After a few seconds the factory reset instructions appear. Use the volume button to navigate and the power button to select.
My coby/kyros is not picking up the internet with wi fi
Some devices need the Wi-Fi service turned on/enabled. Please check your devices settings to be sure that Wi-Fi is "On"!
32helpful
4answers
Screen is frozen will not turn off or go back to main menue
im having the same problem no solution.when i try to turn it on it just freezes on coby.HELP FAST PLEASE!
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
