I need (and I want to) to clean my Espresso machine. Cappuccino cleaning goes well, but Coffee (and Entire, therefore) cleaning just don't start. Ipressed "cleaning" button after I've selected coffee cleaning and all I'd got was just a beep. What should I do?
SOURCE: Poor frothing
You need to check (or replace) the air-intake nozzle which is located inside the coffee outlet. You will sure loose the good froth if that part is not clean or replaced. There should be proper amount of air input to produced the proper froth.
Rihel Calma
Philippines
SOURCE: I have a franke flair coffee machine when you
DESCALING
The Saphira has an integrated descaling program. The procedure takes about 60 minutes.
Once started, the descaling procedure may not be stopped.
• When acid-containing descalers are used, immediately remove any splashes or drops on
sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety
precautions.
• Turn off the Saphira by pressing the "ON/OFF" button.
• Press the button "Descale" until an acoustic signal is heard.
• Display: EMPTY
DRIP TRAY (Fig.1)
• Display: INSERT AGENT
IN TANK
• Display: PRESS
DECALCIFYING
Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty
water tank.
Place a sufficiently large container under the steam tube and the coffee delivery outlet.
• Press the Descale button
• Display: UNIT
DECALCIFYING
• Display: PLEASE
WAIT
• An acoustic signal is heard.
• Display: EMPTY
DRIP TRAY (Fig.1)
• Display: FILL
WATER TANK
• Display: PRESS
DECALCIFYING
• Display: UNIT
DECALCIFYING
• Display: PLEASE
WAIT
• Display: EMPTY
DRIP TRAY
• Display: CLEAN
CONTACTS
Good Luck
[email protected]
SOURCE: Our Franke Flair is well cared for! Has been
Remove the water tank out.Then turn off the machine.Then turn on the machine.It will give message, water tank out or no water tank.Insert water tank then see.If it go further "please wait".
But if its still not going beyond please wait, then its internal fault.The temperature thermostat is stopped working or its not heating inside.So the unit is just displaying please wait.The thermostat and heating element has to be checked and replaced.------------
This will help.Thanks.Helpmech.
