Question about Rotel RB-1090 Amplifier
Goes in protection
O/p circuits resistance burnt i want circuit diagrame of the same
    New Friend:
    Problem Solver:
  • 9 Answers
Http://911manuals.com/preview/Rotel/RB-1090-B-EN1-921-ROR.png
go to that link and drag and drop your image in your pc
Posted on Jun 14, 2014
SOURCE:
Pontiac vibe abs fuse diagram shows fuses but the actual is a link fuse how can I determine if it's burnt and do I need to replace the whole link fuse
The fusible link is essentially an in line fuse on the positive terminal of the battery. To determine if the fusible link has been blown , one test lead of your ohmmeter should be on the positive terminal of the battery and the other test lead should be on the end of the fusible link going to the circuit it protects. If the link is ok, then the ohmmeter will read the same resistance as when the test leads are touched together, or very low resistance, usually less than 0.2 ohms. Replace if bad. Auto parts stores should have them. My preference would be NAPA
Apr 15, 2018 | Pontiac Vibe Cars & Trucks
What causes mains fuse to blow ?
A large short!. A short is a hot wire unintentionally touching ground- a metal piece of the frame. It will immediately cause sparking and blow a fuse. Also, an electric motor can have an internal short and blow the fuse for that circuit.
To find what is blowing the fuse, you have to follow every circuit that fuse protects until you find the source of the short. Look for burnt wires, like maybe too close to exhaust. Also a shorted wire can be bundled within a wiring harness, touching other wires and blowing a fuse. Since it is a main fuse, you will probably need a wiring diagram to trace all the circuits which that fuse protects. Try to isolate parts of circuits, like disconnecting the electrical connector at the ignition switch and then see if a new fuse blows. Keep working through each circuit like that until you see results. If some part or component is disconnected and the fuse doesn't blow, then you may be onto it- it could be that part you disconnected, or the wiring associated with the part.
Find a wiring diagram and see what all is part of that fuse. Good luck.
Oct 14, 2017 | Cars & Trucks
Why would I be blowing my tail lights on a 99 Buick Regal
High resistance in the circuit .Is the bulb socket burnt looking ? Do you know how to do automotive electrical testing ? More specific ,voltage drop testing ?
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Do you know what a wiring diagram is an how to use one ? Free wiring diagrams at http://www.bbbind.com/free_tsb.html
Mar 27, 2017 | Buick Cars & Trucks
After many years of good service my Dimension 4 does not microwave. It goes through all the motions but doens not heat the food. the convection and grill functions are working fine. HELP!
Hi Michael,
i think something wrong with its high-tension circuit or your magnitron is bad.
the minor fault is open of therm stat for protection.
or burnt fuse in circuit.
regards,
nuwan.
Jan 09, 2014 | Panasonic NN-T888S Convection/Microwave...
Str f6707a circuit diagram
People who repair tvs for a living rarely need a schematic Most problems are aging electrolytic capacitors. Failed voltage rectifiers or voltage regulators, high voltage section problems (including very low ohm resisters or wire wound resisters) X-ray protection circuits or the fly-back transformer. Each has their own symptoms, and methods of troubleshooting.
Oct 20, 2013 | Televison & Video
Burn marks on circuit board
This can happen over time, the connection points get a little resistance build up and discolor from the heat. This resistance comes from the moisture, steam and spills. The protective devices on the board and machine are designed to fail safe.
I would suggest replacing the board after inspecting the wiring harness from the board down through the door and to the motor.
Apr 24, 2010 | Maytag MDB7100AWB Dishwasher
Dometic RV Rooftop A/C stopped working. Burnt electrical smell
if you can find a decent a/c mn in the area he might be able to patch you up until you get to an authorized dealer?
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
Was given a Coleman power drill, model CMD8189. The charger is inoperable. The two resisters on the charger internal circuit board have been fried. The resistor codes have been burnt off, so I cannot
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
May 05, 2009 | Coleman Cable Coleman 18 Volt Combo Drill...
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Need schematic diagram, some advice and ultimately replacement parts
You have something in short circuit in power supply pattern, so filter coils are burnt. It may be voltage regulator, or regulating transistor, electrolytic capacitor or even shorted diode at pwr. input serving to protect in case of inverse polarity applied. Check all for short. Was it reverse polarity or overvoltage occured?
Mladen,
mladen@propilots.net
Mar 18, 2008 | Lowrance GPS
Rotel RB-1090 Amplifier Logo
125 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
