My Canon MP190 was scanning just fine until error code E42 showed up and refused any more scans. Help!
Error 42 indicates scanner failure. It is sometimes caused due to loose /
faulty scanner cable that connects scanner to motherboard.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
SOURCE: Canon MP190 ScanGear error
Hi ....
Its always a pleasure to meet someone who has done the initial troubleshooting themself ... so looking at your comments, you have already tried the hardware and the drivers steps ... it shows that the issue is not with the device but something with your system ...
To me, it looks like the necessary files for the scan to work is missing from your system which is USBSCAN.SYS. This is a windows system file which is required by the scan drivers ...
Note: Make sure you are searching the hidden files too as this is a system file and could be hidden.
I think this file is missing from the computer which is causing the problem. But there is another possibility as well. There are some services of the computer that need to be started to make sure that the device works file. The services are for everything like spooler services for printer so similarly there are WIA (Windows Image Acquisition) Service or Stimon(98 or ME) services for scanner depending upon your operating system.
It might be possible that these services are stoped or disabled. Follow the below steps to enable those servers:
How to start the Windows Imaging Acquisition (WIA) Service (Win XP)
This brings up the 'Windows Image Acquisition (WIA) Properties' window seen below.
How to start STIMON (Windows 98 & Me)
Well according to me, this should resolve the problem. Just one more very important thing ....
Don't forget to vote if this helps :) ... Cheers ...
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
Best Solution
posted on Sep 05, 2009
the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
SOURCE: my canon mx320 multi function
Need to reset the cartridge.
How to fix the printing problem when Canon
PIXMA MX320 series detected the errors in your cartridge?
After
refilling the cartridge, the next thing to do is to reset the cartridge.
This will clear your printer from displaying common printer errors like
U041, U042, U053,
U051 and U052. The importance of the "reset the cartridge"
procedure is to avoid the printer from detecting your cartridge as
reused one. The steps below is recommended to do after refilling an ink
cartridge.
1. Turn off your printer
2. Press and hold the
STOP/RESET button
3. Press and hold Power ON button
4. While
holding the Power ON button, release the STOP/RESET button
5. While
holding still the Power ON button, press twice the STOP/RESET button
6.
Release the Power ON button
7. Wait until it display an "idle"
message. It will take about a minute.
8. When "idle" appear, open
the top cover to expose the cartridges.
9. Lift up the cover for
cartridge holder and take out both the black and color cartridges
10.
Return the cover of cartridge holder and turn off the printer
11.
Return the top cover and turn on the printer again
12. After the
printer initialize, return the cartridges.
For error
U162 or U163 All functions of the all-in-one printer will stop and
your printer will not work.
1. Turn off
your printer an turn it on again
2. After the printer initialize
try to copy or print. The error will appear.
3. When the error is
displayed on the display panel of the printer, Press and Hold the
STOP/RESET button and wait until it self restart.
4. Release the
STOP/RESET button the the printer is restarting.
5. Wait for a few
seconds and the pending print jobs will commence.
Please give this solution a good ratings. thanks
