I was trying to remove the micro sim adaptor when i found it is stuck,later on it did come out but with a fuse like thin wire-terminal that goes in the sim card slot, now whenever I insert a sim it doesnt recognize it. obviously because i have mutilated it..newaz....tried my luck with the nokia care and they adviced me not to risk repairing it as it could make the phone completely useless (right now its partially useless)...and without hesitation they suggsted me to use it as an iPOD...lol but it hurts...so please help me out....i just want it repaired at any cost.
SOURCE: Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
SOURCE: offline
try open ur handset and make the pcb warm with ur hairdryer and fix it again i think it is due 2 moisture and it should work as its not picking simcard.try it and reply me with results.
SOURCE: nokia 6085 does not recognize sim card
your card is trashed. the wwtnees corruped all your files. it you put it in a computer and it never registers than its offically dead
SOURCE: nokia 5610 d1 restarting during startup
its a software problem just get it software update from nokia care
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
