Microsoft Windows XP Professional Logo
Posted on Feb 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code 28 driver for xp
I want to make network of an analyzer with my computer and thats need code 28 for the installation.
Brian Sullivan
Level 3:
  • Microsoft Master 27,725 Answers
  • Posted on Feb 14, 2013
Brian Sullivan
Microsoft Master
Level 3:
Answers
27725
Questions
Helped
5669839
Points
79191
Microsoft Help and Support says that "Code 28 (The drivers for this device are not installed)" appears when the Windows Sound System Compatible Driver for the Windows 2000 operating system is deleted upon the upgrade to Windows XP. It's possible to repair this code.
Click on "Start." On the "Start" menu, click on "Control Panel." In the "Control Panel" folder, click on "Performance and Maintenance." Click on the "System" folder in the "Performance and Maintenance" folder. Click on the tab titled "Hardware." Click on the box that says "Device Manager." Click on "Sound, Video, and Game Controllers." Right-click on the device that prompts Windows XP to display Code 28 (it should be Windows Sound System Compatible Driver, also called the WDM driver). A drop-down menu will appear. Click on "Update" and an Update Wizard will guide you through the installation of a new device driver, which should stop Code 28 from appearing on Windows XP.
or
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers If your computer came with a motherboard disk the drivers could be on it or you might download slimdrivers. Rather doing a driver hunt http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 Note: it will find all of your outdated drivers This is a free driver solutions which will automatically search for and find the correct driver You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. It might take some time being free
5 Related Answers
soulwax36
  • 37 Answers
  • Posted on Oct 06, 2009
SOURCE: driver won't download intellinet ethernet driver os 98
Try to manualy specify the path to your driver using driver update.
Anonymous
  • 85 Answers
  • Posted on Oct 25, 2010
SOURCE: Can't connect to the internet new hard drive
You need the Intel Pro 100 driver for XP. Go to the following web link at Intel: http://www.intel.com/p/en_US/support/highlights/network/pro100ve and download the driver. Copy it to a flash drive. Put the flash drive into your PC that needs the LAN driver and double-click it to install it.
Testimonial: "worked as advertised, thanks for the advise. Iam not connected"
urlftp
Joe Brady
  • 300 Answers
  • Posted on Dec 02, 2010
SOURCE: How can I download code 28 drivers to a computer
do you have a usb memory card? or a blank cd those are two easy ways to transfer data between the two, good luck! take care.
Testimonial: "I have download software to CDs and USB Keys that will review drivers that are on my computer and then tell me to connect to the internet. Not useful"
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Mar 19, 2011
SOURCE: device drivers(code 28) for
Welcome to Fixya. The drivers for this device are not installed. (Code 28).
Install the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site.
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to install the driver.
If you have the CD or installer of your Network Controller you need to install it or you can provide me the make and the model of your computer so that i can send you the link for the driver.
If you have questions please let me know. Thanks for using Fixya
rocky_eagles
M V Tech
  • 149 Answers
  • Posted on Oct 12, 2011
SOURCE: How do I fix The
you probably installing a wrong driver.. look for the correct vendor and model.. and make sure it compatible with your operating system (Windows xp / 2k / 98 / ME / 7 / else)
hopefully this give you a jumpstart..
Code 28 driver is not installed in my laptop, please tell me how i can install code 28 dricer and i have nothing any cd.
The Code 28 driver means that there is a piece of hardware installed on your computer, but the driver wasn't installed correctly. If you have recently installed a piece of hardware, then you may need to find the correct driver for it. These are often found on the manufacturers websites.
If this doesn't work, then remove any hardware you have recently added, and reboot the machine. If the code 28 error goes, then at least you know exactly what's causing it, and can re-troubleshoot from there.
5helpful
2answers
Code 28 can not be install on my pc
error code 28, means a Driver Error,
the solution is to go to the device manager,
1.) start, control panel, system, hardware, device manager,
2.) locate a device with a yellow highlight
3.) right click it and select update , follow the onscreen instructions
or
reinstall the driver using the driver cd. that came with it.
if that fails you need to go to the manufactures website for that particular device , locate the driver and download it, then install it. PS if its on the mainboard you can go to the OEM system builder you have like dell or hp , if you dont have and oem system go to the mainboad manufactures web site, Biostar and MSI.
1helpful
2answers
Device drivers(code 28) for network controller not installed
Install the driver
1helpful
Can't connect to the internet new hard drive installed, windows XP pro installed when checking hardware : says ethernet controller driver - not installed. tried finding it on the installation CD, get a...
My computer says code 28 I do not have any driver installed for multimedia audio controller i have no sound and my cd rom does not get reconized
For Code errors refer to microsoft site: http://support.microsoft.com/kb/125174
The drivers for this device are not installed (Code 28).
To reinstall the drivers for this device, click Reinstall Driver
Procedure
Step 1
Click on "Start."
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Hope this help
1helpful
3answers
I reinstalled Windows XP to my computer and now i cant get the internet. There is a yellow question mark and exlmation point next to Ethernet Controller and it has a code 28 error.
You should have had 2 cds that came with your computer. The 2nd one has all the drivers on it. Install the drivers and your problem will go away.
Cannot fix code 28 for network controller for dell1525 laptop
If you are getting a code 28 then you will need to download a new driver on another computer for the network card. If you have a wireless adapter that you can connect to the computer and your router has wireless capability then that could work as well but you will need to get a new driver on to that computer some how.
Finding the driver will be easy though. You can go to the computer's manufacturer website, or the website of the network card's manufacturer and search for it there. Shouldn't be too hard to find but if you can't find it let me know and I will get you a link.
7helpful
3answers
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
7helpful
3answers
I'm cannt to connect my digital camera to my windows via USB port. after this, I received message : The drivers for this device are not installed (code 28), what can I do?
Thx...
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
