Question about Sony KP-53XBR45 53" Rear Projection Television
TV has sound no picture, Sony Videoscope xbr
I just bought this tv used, sony videoscope xbr 53", and when I got it home, the sound worked fine, but there was absolutely no picture. Also the timer/standby light flashes and does not stay constant. It was sprinkling out and I covered it up with plastic, but the back got a little moisture in it. What's up?
  • ra_17 Feb 22, 2009
    I have a Sony Videoscope XBR, model number KP-53KB R45. No Sound, No Picture. When powered on it turns on, blinks twice and immediately turns off.
    Can you help? Thank you.
  • gbrodt62 May 11, 2010
    KP53XBR45 6 short 1 longer flash
  • 4,234 Answers
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Posted on Feb 10, 2009
SOURCE:
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
My sony videoscope XBR tv has a pink picture and no control. Also nothing is in enlish.
the model listed is a very old set---parts may not be available----language can be selected in the menu but the pink may be a adjustment of the screens (controls) or a circuit problem.
Aug 26, 2012 | Sony KP-53XBR45 53" Rear Projection...
Can't turn off pip on sony XBR videoscope TV
Look on your TV remote and press the button clearly labled PIP or Picture-In-Picture and press that button over and over. It will cycle through all the PIP modes until it turns it off!
May 02, 2011 | Televison & Video
HI I have a 1998 Sony Videoscope XBR 53 in. Projection TV. When you turn it on the sound is fine but sometimes the picture comes right on and sometimes it can take hours. Can anyone give me some advice....
hello well it's and old tv, my guess it could be capacitors in the power supply or even dry joints on the power supply board, it would be best to have someone with electronic experience to have a look at it
regards
shaun
Oct 06, 2010 | Sony KP-53S65 53" Rear Projection...
MY TV IS ON STANDBY WHAT DOES IT MEAN AND HOW DO I GET IT TO WORK I CAN HEAR SOUND AND CHANGE CHANNELS BUT NO PICTURE STANDBY LIGHT IS ON
my sony videoscope xbr was in storage for a while. I brought it home and let it warm up before I plugged it in. now the standby light blinks all the time. I have sound but no picture. any idea what to do?
Sep 13, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
This is a convergence problem. Look in the back for a couple of large black ICs attached to a heatsnik. These should be marked STKxxx. These are the convergence ICs and either have bad connections or are defective. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. There may be other parts that need to be replaced as well. I'll look up your model to find the other parts to check. The convergence board as an assembly, I believe, is no longer available. The parts that you require are available.
Dan
Sep 18, 2008 | Televison & Video
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Apr 05, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
1,200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
