Lands Phones Logo
Turns on but no dial tone - Nortel MERIDIAN M2250 ATTENDANT CONSOLE (NT6G00-35-003)
I have a Nortel Jazz 420 and it suddenly turned on pulse mode instead tone mode. How could I turn it on tone mode ? Pierre
Try this
Tone dialing allows your telephone to communicate with devices and services that respond to tone signals, such as answering machines, fax, or automatic switchboards. Want to learn how to switch from pulse to tone dialing on the Nortel phone? Follow these simple steps.
While on an active line, or after selecting the line, press # and the phone will switch from pulse to tone dialing. After you hang up the phone, your phone will return to pulse dialing. You may repeat these steps as needed.
I cant get a dial tone to call out says line in use but I have checked and unplugged all 4 lines still no dial tone everything else is good no dial tone
Try:
Turn off power for the base.
Turn off phone and take out batteries.
Wait few seconds then put batteries back.
Will help if you unplug and plug the cables.
1helpful
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
2helpful
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 • Cell Phones
Dial tone of my phone disappears whenever i switch on my computer and my d link dial up modem can't find dial tone. What should i do?
Disconnect the telephone-cable from the computer's modem.
Does your telephone regain the dial-tone?
If so, then replace the computer's modem -- it is going "off-hook" as soon as you turn on the computer, not just when you try to use the modem to open a dial-up session.
4helpful
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
1helpful
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
Can't stop phone from announcing each digit as I dial
Dear
Please go to tone setting & turn off key pad tone
Thanks
Mar 13, 2009 • Cell Phones
Tone volume on tough tone dialing pad
Instr man is here:
http://www.home-electronics.net/ge/pc/IB/27957GE1_IB.pdf
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
