There is a number on the bottom of the camera, but I am not sure if that is the serial number. Also where would I find the serial number for the lenses?
The serial number is on the bottom of the camera. For lenses, the location varies but usually is either near the Nikon logo on the barrel or near the mount. See the photos on this page.
SOURCE: May I use a Soligor 24D Flash on my new Nikon D40X Digital Camera
You can purchase an off-camera flash sync adaptor at any good camera store, complete with extension cable. The should work fine.
SOURCE: Nikon d40x LCD screen stopped working
Have you tried the 'Menu' button? If you've turned off 'Review' in the settings menu, the screen doesn't show anything after you take a picture. If the screen doesn't come on when you push the 'Menu' button with a charged battery installed, your camera will need to be repaired.
SOURCE: Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
SOURCE: nikon d40x camera not working
The camera has a bad shutter or a bad sequence plate motor .
If you need help further contact
Berrie Smith Camera Repair
SOURCE: Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
