On start up the BIOS screen gets as far as Testing memory. Please wait. It tells me the Processors and System memory size and system memory speed. Then goes no further. The indicator light on the keyboard goes out. It was working before I went on holiday for two weeks. Has powering it down caused a problem? Any ideas
This is common, if your place was cold its possible that something has died when turning on again, you could try and pull out ram in an order to see if one has failed, get the memtest download and make a boot disk to test the ram has not become faulty, test each stick alone, Hiren boot disk has all the good stuff for testing, its a free tecky tool for engineers.
SOURCE: No Boot on 1600sc
The easy answer is: Did you ensure the CPU fan connector is attached to the PROPER motherboard CPU fan power pins? The 2nd easy answer is: Are you sure your CPU is properly placed inside the socket? Could it be tilted slightly up on one side? The more complicated 3rd answer is: I've seen people use the spray can of AIR, which, believe it or not causes a moisture problem AND can overly cool a component. Although the motherboard looks fine, it won't boot or power on until the part(s) rewarm to room temperature or the moisture dissipates. This is how I solve this problem. I remove the motherboard or open it completely up to clean it with 80psi of compressed air. (remove all components) If it had previously been cleaned with a can of AIR, I let it sit for half an hour. When putting the parts back together (leave the HD, the CD, the floppy disconnected), (oh...ensure your front panel connectors are properly on the correct motherboard pins too.) 1)take extra caution with both the video card and the memory chip slots!! Inspect the video card gold edge and video card slot for a few strands of carpet fiber or DUST bunnies wedged or attached to the card/slot (which causes the computer to not power ON) 2) Inspect the memory sticks and memory slots in the same manner. (I had to see it with a magnifying glass, to see the problem) Once back together, if it boots, I'm done. If it didn't boot, I replace the power supply. If that didn't solve it, I reposition or change the RAM memory. Attention to detail is the key to success. ZT3000 "Beta tester of "0"s and "1's"
SOURCE: Dell PowerEdge 2450 Server issues
Power down thy system,pull the hard drive half way out remove all cards from the slots power up see if you go pass the processor etc,if not go into the system setup f2,integrated devices turn them all.see if you go further if you do go back in turn the devices on one by one,do not put the hard drives in yet.wait until you turn the scsi controler assuming you are using the integrated card.If you still cant the on board raid controler uses a raid dim if you can change thi note it must be the same type.
Good luck
SOURCE: bios for adapter 0 is not installed 4600 poweredge
There are problem with Operating System ,It has been corrupted so pls re-install the operating system .
SOURCE: Hi, we have an Dell PowerEdge
Most of the systems will not start back when the system shutdown happens due to some power conflicts.
To resolve your issue, please follow the below steps:
1. Make sure that all the connections to your server is proper now.
2. Press and hold the system Power ON Switch in your server for more than 20 seconds continuously.
3. now release the power button and press it back gently once normally to start you machine.
4. In this way most of the system will be powered up.
Please follow the above steps and let me know your comments. If still the problem persists, then please provide some more information about the problem which you got in following the above steps as that will be useful to assist you back.
Thanks
SOURCE: Cannot Boot Dell Poweredge 1650. Stuck on Dell splash screen
May be a HDD error or possibly a virus.
