Put white vinegar in the water and run it through your tub. Fill the tub to it's maximum running capacity, which is normally just above the jets, and pour a gallon of vinegar in the water with it. Let it run with the vinegar for about 20 minutes, then turn it off and let the vinegar sit in the jets for about 30 minutes. Then start up the jets again for about another 10 minutes and drain. Then run plan water through the jets for about 15 minutes, drain and that should do it. I would recommend doing this at least once every 2 months depending on your water type and how often you use the tub.
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
SOURCE: How to Change White Water Whirlpool Tub Jet Hardware
First step is to remove the old hardware so you have something to compare it to. THere are two types/sizes of tub faucets on the market for deck mounted applications. If yours is mounted on the tub deck then it is a deck mounted application.
The faucet spread (distance between the threaded nipples on the bottom of the faucet) is going to be something close to 8" or it will be of variable distance. If the two handles and the spout are connected via hose then they are of variable length.
Bring the old faucet into the hardware store and compare it so you know you are getting the correct one. It is not hard but also not fun to have to adjust the holes in the tub deck to accommodate a different size.
AS for the suction.....I am assuming that you are referring to the inlet part o the pumping system and all of the equipment behind the tub. I always recommend that you use parts from the same manufacturer. It is extremely helpful to call them with all of the numbers you have to get a list of acceptable replacement parts.
Hope this helps.
I recommend that you consider spray painting the gold hardware with brushed nickel rusteoleum paint. IF you decide to go this route you must lightly abrade the gold surface with emery cloth then prime with rusteoleum primer, let that dry and the final coat will be the brushed nickel. I have done this and it turned out excellent. I get compliments on it.
Regarding your other issues, you will be happiest with white water parts. That being said, it is likely that locally procured parts might fit. I would get one set of parts and try them.
You will likely find the model number etc. on a plate in the mechanical compartment of the spa.
SOURCE: can you cap off the jets of a whirlpool tub if you
you can but it's not worth the trouble of doing it! lots of fiberglass and you need to have access to the whole tub on the sides
SOURCE: whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
