Printing has fading in the middle of the page. Does not matter if the page is place vertical or not the fading is in the same place about 5cm across the page
SOURCE: black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
SOURCE: RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
SOURCE: Printing from the wrong tray on the Ricoh C410 DN
these settings need to be done with the RPCS printer driver, go to properties and then custom settings from there you can tell the printer where to print from.
http://www.websitetoolbox.com/mb/copierquestions
SOURCE: Ricoh cl3500N printing with blank streaks in
The voids and blotches can be a bad black pcu, the voids san also be toner on the glass slat obove the pcu,s there are 4 slats one for each color, on the pcu itself on the upper side is a narrow long opening, the glass slat is above this opening when the pcu is in the printer. It will take a flashlight to see any toner on the glass.
-Carl
SOURCE: My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
