Question about Pentair Challenger High Head 1.5 Hp Pump Up Rated
Our Pentair Challenger 1.5 hp self priming pump is squealing.
It is making a high pitch squeal and leaking a little bit of water. It did stop while the polaris was connected. But then it resumed.
  • Anonymous Mar 25, 2009
    Pentair Challenger 1.5 hp self priming pump is squealing."
    Problem Solver:
  • 10 Answers
Where is the water leaking from and does the noise start only when the pump starts or the entire time its running..
Posted on Mar 11, 2009
SOURCE:
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
How do I know if I need a new water pump?
there is little weep hole under your water pump and coolant will leak out of it once it needs to be replaced. Your water pump will sometimes make an awful high pitched squeal without leaking which in that case would also require replacing. I'd also suggest checking heater hoses because they can also leak.
Sep 14, 2014 | 2002 Saturn S-Series
Challenger pump leaking at the band
You may need a seal plate o-ring or you may have a shaft seal leak. See if you can determine if there is water running down the outside of the seal plate from where the motor mates to the seal plate.
Feb 15, 2012 | Pentair 1 HP Challenger Pump
Pentair challenger 1 horse pump; motor running ok, sounds a bit noisy, now does not pump at full force, water does not fill the pot even after primed start, pressure guage reads 0 psi before read 20...
check the impeller for debris. you will have to take the metal band off that connects the wet end to the seal plate. inspect the impeller for debris. lube all o-rings and reassemble. if that does not work, investigate a blockage in the suction side plumbing.
Aug 12, 2011 | Pentair 1 HP Challenger Pump
We have a Pentair Challenger 1 1/2 switchless motor. While running it is very loud...is this normal?
check amount of water pumping if pot is not full you could have somthing in the impeller like small leaves
Aug 21, 2010 | Pentair Challenger High Head 1.5 Hp Pump...
My pentair whisperflo is making a load squealing sound. not sure if it is motor or pump
When you have noise in the pump it is usually a rumbel or rattel. If you have a squealing it is probally in your motor and is more than likly a bad bearing. If you have any water leaking at your seal this is probally the problem and it will just get worse. Sorry to say you are very close to a new motor.
Dec 05, 2009 | Pentair 1.0 Hp Whisperflo Pump
I have a challenger pool pump that has a very high pitch sound
The motor bearings are probably starting to fail. If you winterize the pool I would take the motor portion off the pump and have a local electric motor repair shop look at it. A simple bearing change and new pump seal would run $50 or less at most places. If not, shock the pool and run the pump overnight to balance the water and then pull the motor for the repair. It will probably only take a day or so for it to be completed.
Aug 30, 2009 | Pentair Challenger 1 1/2 Hp In Ground Pool...
Challenger 1 hp will not pump.
most common problems...dirty filter and/or clogged impeller
Jun 24, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Our 1.5 HP pentair challenger pump isn't holding its prime
Usually, if a pump will not hold its prime, there is an air leak somewhere in the system. Things to look for are small leaks around the equipment-could be a bad o-ring. If you do not see any leaks, turn off the pump, remove the lid from the basket, check it for a hairline crack and check the o-ring under the lid to see if it is the cause of the loss of pressure.
Apr 26, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Pentair Challenger High Head 1.5 Hp Pump Up Rated Logo
798 people viewed this question
Top Pentair Garden Experts
roeb
john h
Marvin
Marvin
Are you a Pentair Garden Expert? Answer questions, earn points and help others
