Evening, We recently bought a Chicco Liteway and the straps for smaller babies (extra hoops) appear to be in a different place to those on the manual. After looking around the internet, it seems we have the international model. Does anyone know how to set up the stroller so that the strap are shorter, using the adjustable hoops? Our hoops are at the bottom of the back, rather than just below where the straps start (as you would expect!). Thanks in advance!
SOURCE: Chicco Liteway
Go here to print off product manual: http://www.chiccousa.com/gear/strollers/liteway/liteway-fuego.aspx
SOURCE: need raincover for chicco liteway stroller
If you email this addres [email protected] you will be able to purchase this part.
I hope this helps.
SOURCE: need rear wheel for my chicco litewat stroller
Hi, With he Chicco strollers there are at least 2 mechanisms for the rear wheels. You need to check which versions you have. 1) you will find a metal ball press stud on either side Of the chassis. Take a screw driver and push that metal ball in as far as you can to clear the housing for the wheel. Then pull the wheel away from the chassis. 2) Repeat for the other side 3) if both rear wheels come away WITH two a v shaped hinged metal rod then you can simply replace the rear wheels. I have seen them on eBay. 4) if yours pulls away and the hinged bracket has a material strap to it then these are not meant to be removed or at least I would not necessarily recommend that but of course the choice is still yours. You may need to purchase a replacement chassis again can be purchased on eBay. Hope this helps. Liz.
SOURCE: how do i reassemble chicco
Here is your manual. Should show the way to re-string it.
http://www.chiccousa.com/Files/pdf/product-manuals/KF30instructions3_00.pdf
