D-Link DIR-615 Wireless Router Logo
Anonymous Posted on Feb 13, 2013
Reset my dlink dir 615 router and now internet light stays flashing orange
I needed tp change the password for my dlink DIR - 615 router and i had held the reset button to restore it to its factory settings since I could not access the admin dlink panel without the correct password and now that it is up and running again i can not get the internet light to stop flashing orange/amber to connect to the internet on all devices i wish to connect to the net with which is one other laptop currently i am using a tethered connection to a desktop which is for some reason giving me an internet connection,
  • Anonymous Feb 13, 2013
    Now i have went into the setup on the main comp for the Dlink and everything is set up yet the internet light wont stop flashing amber/orange i have connected a laptop back up to it but the internet it'self is not working
NAVA
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 79 Answers
  • Posted on Feb 15, 2013
 NAVA
Expert
Level 2:
New Friend:
Greenhorn:
Answers
79
Questions
0
Helped
17063
Points
162
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
  • 1 more comment
  • Anonymous Feb 18, 2013
    Well I have tried all forms of setting up the router all over again and yet still nothing seems to have changed ive got the security set up as well as the wireless ive used the wizards to set them up I have even tried manually setting them up and still nothing.
  • Anonymous Feb 19, 2013
    all cords are in there corrisponding spots
  •  NAVA
    NAVA Feb 19, 2013
    You mention that you have internet when you tethered to the desktop PC, is that still the case?
3 Related Answers
Anonymous
  • 404 Answers
  • Posted on Aug 08, 2009
SOURCE: dlink DIR-615 wireless connection problem
hi. with regards to your concern. there is a possibility that the wireless network adapter driver is corrupted.. try uninstalling the driver for your wireless adapter and reinstall again. once setup is done, view the available wireless connection and connect.. it will ask u the password if there is..then it will connect. if this solution dont work.. try to check your wireless settings, maybe there is a problem on the settings..
clb199
clb199
  • 164 Answers
  • Posted on Nov 24, 2009
SOURCE: Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Testimonial: "There was a problem with router itself, after replacement everything works fine. Thank you for an advice"
Anonymous
  • 32281 Answers
  • Posted on Oct 31, 2010
SOURCE: I forgot my password to
To reset the D-Link back to the default settings, Press and hold the RESET button and then power up the D-Link. Hold the RESET button for 5 secs until the LEDs flash.
Now you can enter the default login & password.
Dlink DIR-615 won't hard reset. dont know the password
Try this please:
http://www.geckoandfly.com/5890/reset-d-link-router-factory-settings-and-default-password/
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
My instruction manual is in Chinese, i am using a mac and i cannot connect wirelessly to the internet, I have a DIR-605 router.
well here is a link to obtain the manual http://www.dlink.com/products/?pid=DIR-615
you need to select Support Resources Tab and choose the revision type you have. then you select product manual. One example is this one "DIR-615 no rev. http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
2answers
My DIR-615 Dlink router always has the Orange globe. How am i supposed to fix this, the modem works perfectly fine as i tersted it without the router and internet works. But my wife needs the laptop and...
In the web interface of dir-615 switch it to router mode, adjust wan connection (username, password... depend on your Internet provider, in fact, it is easier to ask their tech support to provide all necessary information) then configure wireless network.
Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
5helpful
How do i reset my DIR-615 SO I can make a new password?
To reset the DLink back to the factory defaults - power up the DLink and press and hold the RESET button until the LEDs flash.
You can then reconfigure the wireless router with new settings.
1helpful
Cant get on the settings page on my DLINK dir-615 router
Turn the router off.
Straighten one end of a Norwegian paper-clip,
and insert it into the small hole in the back of the router,
to "reset" the router to the "factory" settings.
Turn the router on, connect to its built-in web-interface,
and the "default" ID/password should now work.
Change the password.
Rerun the "Wireless Network Setup Wizard",
to recreate your wireless network.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
