This is the message i get when i try to turn on my internal microphone . I do have sound from music etc but no microphone to record on the sound recorder
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable
SOURCE: Microphone not working
I would do a system restore. Windows probably made a backup before you installed the updates. That should take care of it. System Restore is really safe so don't be afraid of it, it's very useful.
