Receiver- VIP 222k remotes- 21.0 ir/ufh pro
Hello, German Quinchia!
I would be happy to provide assistance on this. It sounds like the remote itself may need to be setup correctly. Since this is going to be the second TV, on the bottom of the remote, make sure there is a blue 2 at the bottom instead of a green 1. Once you have the blue 2 showing, try addressing the remote again.
If the problem persists, remove the battery cover. Inside will be a switch. Make sure the switch is toggled to UHF rather than IR. Let me know here if the problem still continues after that.
Tommy Faust
DISH Social Media Representative
SOURCE: dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
SOURCE: Dish 20.0 IR Remote works for awhile then it
I MAY have a solution!! We too have the VIP722 Dish Network receiver. Ours is the "K" model. I called the place where we purchased the TV and they said that the "brightness" on the TV may need to be turned down. He walked me through this, and it worked. The remote WORKS now!! Our TV is a 40" Sony Bravia that we purchased a couple of months ago. Evidently at night, the TV was so bright in the room, it interfered with the Infared Remote control. By turning down "off" brightness detector on the TV, the IR remote was able to send the signal to the receiver. Our TV is on a cabinet and the receiver is directly underneath on a shelf. I hope this solves your problem and anyone else's that may have this problem with the remote.
SOURCE: Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
Hope this helps!
SOURCE: How do I program an Echostar 5.4 IR to control a
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post recently and wanted to see if I could help. The best codes for the 5.4 IR remote are 500, 578, 514 and 758. I will also list here for you the instructions for addressing your DISH remote to your Sony TV. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to email directly at [email protected]. Thanks and have a great day!
Instructions for addressing remote to TV.
Note: The LED will flash three times.
