The clock and lights turn on as if it would heat up but no heat comes out
The clock display works on 120 volts but the burners and oven require 240 volts. I would check the breaker or the receptacle to see if they're bad.They may be supplying only 120 volts. One more less common problem could be the terminal block on the range where the power comes in. Very rarely they will melt. BE SURE TO UNPLUG THE RANGE if you have to check the terminal block. Hope this helps.
SOURCE: Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
SOURCE: Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
[email protected]
SOURCE: My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
my eoc is not working on my oven burners work fine but no clock or oven controls please help
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
