The iPod's shuffle feature lets you randomize playback of albums, songs or even your entire music library. You may also find this feature useful if you want to listen to forgotten tracks in your library or discover songs you haven't listened to yet. Disabling the shuffle feature will return playback of a song list to its standard consecutive order. You can enable and disable the shuffle feature at any time.
Navigate to the main menu. Select "Settings." Scroll to the "Shuffle" option. Select "Songs" or "Albums." If you select "Songs," the iPod Classic will shuffle the songs on whatever song list you listen to. If you select "Albums," the iPod Classic will play all songs of an album you select in order and then randomly select another album. Navigate to the playlist or album to which you want to listen. Play a song to initiate the shuffle. b> iPod Nano and iPod Touch Tap the "Songs" icon on your nano home screen. If you are using an iPod Touch, open the "iPod" application. Navigate to the song list, playlist or album you want to play. Tap the "Shuffle" icon at the top of the list to activate the feature.
SOURCE: Frozen iPod Nano
FOR ALL PERSONS WITH THE FREEZING IPODS AND CANT TURN OFF HERE IS THE SOLUTION
to reset your ipod
switch hold button off and on again then press the menu and the center button simutaneausoly until the apple logo appears and goes bright and there .has been reseted
rate the solution plzzzz thank u
SOURCE: Removing songs from Ipod Nano using Winamp
Seems the playlist detais arent geting removed, only the songs.
So basicly you need to remove the deleted songs from the playlists ? you could probably do it on the ipod screen manually.
if my solution fixed your problem please give me a fixya rateing, becouse im trying to reach the guru status and its up to the voters(you) If I get there or not. I have over 700 solutions here and most of them are unrated!
So thanks alot for rateing!
Press and hold the center button while holding down the menu button. This will reboot your Ipod. Check your IPod cable to see if its shorted. If might have transferred a song and crash in the middle of the transfer.
SOURCE: Deleting songs from Ipod Nano 8GB
When you connect the ipod nano to the computer, you can do one of two things: you can go to the ipod's main home page in itunes and go to the bottom where it will have four options listed. 1 of them should say manually manage files. Click on the check box next to it and it should ask you if you are sure and click yes. Then go into your music folder of your ipod and delete the songs you don't want on there. To add music, all you have to do is click and drag what you want onto the oped. The second way you could do it is to go into your library before connecting your nano to your computer and un-checking all of the boxes next to the music you do not want on your nano and then connect it to a computer and let it sync. The first way is easiest and less time consuming as you only have to do it once. Hope this helps!
SOURCE: charging ipod nanon 4th gen on bose sound-dock
http://www.scosche.com/products/productID/1694
Click on the link above for the solution for your problem
