SOURCE: Nokia 1203-2 security code
If you forgot the security password, then you need to master reset the phone. I recommend you to contact your service provider to get the master reset code.
SOURCE: Master security code for N95 8gb
the defualt sercurity code is 12345, there is no other code,
you can perfome a master reboot of the phone with out the sercurity code my pressing and holding (3,* and the green call button) and powering the phone up keep holding the buttons untill you here the nokia tune, this will reset the whole phone, contact, photos, callander all will be lost so backup first.
but his will get around a security code but not a sim lock or imei lock.
SOURCE: Master reset code for Nokia 6280
how can i get my 6280 mastercode?? my IMEI is 358356004735753
SOURCE: Nokia N73 security code
The default security code for Nokia is 12345
IMEI: 359568011016758
Master code: 4444376533
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
