There is no reset button on those. There is a thermal breaker in the barrel if the heating coils get to hot. If this sticks open then it wont work but you cannot reset it.
On the end there shouldbe a vent which houses the fan you should be able to open this by twisting ? Chech to see if there is hair/fluff/dust blocking this if it's not able to move the motor won't have anything to keep it cooled resulting in smelling burning as the caught up hair fluff and dust burn hope this helps :-)
If you know anything about electronics you could probably fix it. Those kinds of devices have a fusable link in series with the heater and when they exceed their rated temperature then open up to keep things from starting a fire. Typically you can purchase them at a place like Radio Shack if you can determine the temperature and current rating. Good luck.
Then contact your favorite hardware... (or LAMPS +)
and ASK the MOST COMMON clear candelabra bulb socket
That sports a CERAMIC type socket... E12 or E14 ...
I recommend to get a better hair straightener, I bought mine at safrons it's the Karmin G3 Salon Pro with ceramic tourmaline plates to avoid hair damages, it heats up really quick and leave my hair soft, shiny and super straight, hope this helps.
Hi. Yes it is possible to connect the wires with wire nuts. (Without tape! / tape can melt) You must use ceramic / porcelain wire nuts (white) in HOT areas. Make sure it is a clean connection with no copper strands exposed The plastic ones will melt like your connector did. Most appliance parts supply stores will have ceramic / porcelain wire nuts.
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
