The 0-ring that seals the battery compartment is hopelessly damaged, and the hardware store doesn't sell anything that thin.
You can check for parts some websites:
Timex Watch Parts Supply Watch Parts Replacement Watch Bands Watch Crowns...
http://global.timex.com/
TIMEX Movement
Watches for Parts
SOURCE: I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
SOURCE: Timex flix watch
Hello
For some reason, the sound for the alarm and hourly chime is muted. Is there something I can do or is watch defective?
SOURCE: Installing a spring in the Timex Ironman WR 100M watch
That spring is called COIL SPRING and it transmits the signal from the microprocessor to audio membrane fixed to caseback. This is how you hear all the beeps, alarms, e.t.c.
Examine watch movement and you should fine small hole (it can be even marked with an arrow and writing: COIL SPRING).
Fit that coil spring in to the hole and close the caseback. If you hear no sound, you fitted it in the wrong hole, so, refit the coil spring till you find the right hole and hear the beeps.
Rate, please.
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
This one is quite simple. Just remove the watch back with a watch case knife and flick out the old cell then carefully press in the new one (VERY carefully as the movement is made of plastic). fit the back exactly the way it came off (note the direction of the writing).
You can buy O-rings on ebay. I got a 100 pack of assorted O-rings 32-50mm for about $5.00. I found one that fit my Ironman 100, put a thin coating of bike grease on it and installed. Works perfectly!
