I have a Whirlpool Duet Sport washer WFW8300sw00 I start a load of clothes, it sprays water and turns a bit then stops.. After doing this sevral times and water filling about half way in the washer, it completely shuts down nd flashes F20. I have too push the pause button which drains the water out and start over. Usually hving to do this several times, then putting it on rinse and spin to complete my load.
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Hi!
Try selecting different temperature settings. Maybe the mixing valve is not putting in hot water. Try to run it with cold water.
Hi!
Hi!
I checked what you listed and still having the same problem. I have had the washer for about 3 years never having this problem. I dont know if its possible that the county water system we are on decreased our water pressure?
clunk sound when water turns off from filling several times
