Cyberhome CH-DVD 300 DVD Player Logo
Posted on Feb 08, 2009
Status light yellow, won't power on
I have a CyberHome CH-DVD 300 that won't power on. It is plugged in, and the cord looks fine, but the status light is yellow and it won't power on. No where in the manual does it mention what a yellow status light means - only red and green. If I press and hold the power button for 10 seconds (to try and reset) the status light turns red while I'm holding the button in, but as soon as I let off it turns yellow again. Likewise if I try to push and hold the open/close button - the light turns green, but the second I let off it turns yellow again. Any idea what a yellow status light means and/or how to fix it?
  • 3 more comments
  • oaney Feb 11, 2009
    Did you get a fix on this? I inherited the player from a family member. The other thing I noticed is yellow light seems to strobe. I can hear a thumping in the audio as well
  • Anonymous Feb 14, 2009
    I have the same problem. What does the yellow status light mean. When you push and hold one of the other buttons it changes colors.
  • tw2009 Feb 15, 2009
    I got the similar problem for my Cyberhome CH-DVD 300 --- It does not power on. The small status light is yellow. The light turns to red when power on/off button is pushed, and turns green when "open" button is pushed. How about $5.00 for a real solution?
    TCW
  • Anonymous Feb 16, 2009
    That didn't work on mine . . . I tried that before posting the problem. Thanks though.
  • Latdingo1 May 11, 2010
    It didn't work for mine
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
912
Points
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
[email protected]
  • Anonymous Dec 13, 2011
    I'm having the same problem and unfortunately un-plugging and re-plugging was un-successful.
  • Charlie Glass
    Charlie Glass Mar 04, 2015
    Me too
2 Related Answers
Anonymous
  • Posted on Jan 25, 2008
SOURCE: Cyberhome CH-DVD 300 Player Remote?
Try 724
A
Anonymous
  • Posted on May 18, 2008
SOURCE: Cyberhome CH-DVD 300 DVD - YELLOW light indicator of what problem?
I have the same problem, but I know what the cause is. Mine stopped working right after we had a power failure, so I suspected a power problem. The +5V DC supply from the power supply pcb is only at 3V. I removed the wires for the +5V and patched in a USB cable to provide +5V and it is now working fine. I noticed that one of the capacitors on the power supply pcb is buldging on the top, so it's probably bad. I'm going to try to replace it and see if it fixes the problem. The simple answer is that your power supply pcb is not working correctly.
Door won;t open
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
What is required to hook up my cyberhome 300 to my television i was given the unit with only the plug in electrical cord no other cords what else do I need to get to make it work thanks patrick
red/white & yellow cable wire....connect to tv/monitor by color...depending on what jack u plug into on tv (to watch you will have to tune that ch 3/aux/video)...
4helpful
Cyberhome dvd ch dvd 300 changed ntsc to pal by accident
I have done it! All I did was take the yellow video cord and plug it in those progressive scan plug in until I could see a blurry screen enough to be able to see to do a reset, which is under system and did a factory reset. I DID IT AND DAMN PROUD OF IT SINCE THE EXPERTS DIDN'T EVEN KNOW IT!!!!@ Jennifer pc, fl
I bough the CH-DVD300 used. Supposedly all cords,
The yellow is usually the video connector the the other two connectors would be for the right and left channel sound hook-ups.Hope this helps you with you problem.
5helpful
4answers
Marlin P Jones & Assoc. Inc.. has a 5V 2.2A /12V 1.5A cord power supply that will fit into the space where the original power supply was! Lists for $6.95 but online price was $2.95. Works great! Connect 12V supply to the yellow lead and the 5V to the red lead of the output connector, black is ground, common to both supplies. Use QC terminals to the power cord input terminals, remove the cable clamp and the power supply will nestle beautifully in the space without need for support. (Remove the old circuit board plastic (3) and rear brass standoffs and use the front brass standoff for the output cable shield ground connection. (Part No. is 15955-PS) I bought two because I have a 2nd Cyberhome CD-DVD 300 which hasn't crapped out yet.
Looking for actual remote control(not code)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370033038767&ssPageName=MERCOSI_VI_ROSI_PR4_PCN_BIX&refitem=220212413655&itemcount=4&refwidgetloc=closed_view_item&refwidgettype=osi_widget&_trksid=p284.m185&_trkparms=algo%3DSI%26its%3DI%252BIA%26itu%3DIA%252BUCI%26otn%3D4%26ps%3D42
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
