Ford 1998 transit unable to open locks with keys or remote
I, i get this all the time, had lots of old transits. get as many ford keys as you can borrow friends from escort mondeo transit, these locks are **** some 1s key will open it, when doors are open u have to remove locks and soak them in oil leave under engine oil all night, fixes ur prob.
Where is the sender on a 1999 Ford Transit Diesel
SOURCE: transit doors not locking
james i have had the same problem on a transit an trace the problem in the wiring to the rear right door where the wirin goes through the plastic slider between the door and the vehcle i had to cut out the damaged wiring and run new and solder up make sure the wires you put in are long enough too so you can open the door all the way , failing this think logically which is the door opened and closed the most ,ther might be your prob in the wiring between the door and vehcle
SOURCE: ford fiesta ghia 1998 model central locking key
This is a common problem after changing the Key Fob battery.
The solution is to remove the fuse feeding the Cental Locking for 10 minute...Replace then all should work fine
SOURCE: Ford Transit 100 T280 2002 immobiliser fault,
if its a immobiliser fault you may need to get the pump reprogrammed
loc but wont unloc
