When trying to access web interface via browser i get the error 107
Could not find that code on the Bizhub 200 service manual< normally a C will be the start of the code.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
SOURCE: Bizhub 200 config page
I've been having this exact problem with a C351 and it was driving me nuts... no solutions on the internet that I could find so I started investigating further to find something quite interesting... I ran a packet sniffer to capture the data from a browser that worked, and one that didn't. I then telnet'd to port 80 on my machine and manually sent the HTTP request commands. So, the culprit line on my browser sent:
Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, application/x-ms-application, application/x-ms-xbap, application/vnd.ms-xpsdocument, application/xaml+xml, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, */*
Now, this was amazing... I'd remove 1 of those entries, and suddenly it would go from this:
HTTP/1.1 400 Bad Request
Content-Length: 15
Content-Type: text/html
400 Bad Request
To:
HTTP/1.1 200 OK
Set-Cookie: ID=ced917a359fbbe9c98d2dbf444eb034a
Content-Length: 703
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN">
<HTML lang="en">
<HEAD>
<TITLE></TITLE>
<meta http-equiv="Expires" content="0">
.... (more continued)
So I ran the registry editor on my computer, went to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Accepted Documents, saved this to file, and removed one. I had application/vnd.ms-xpsdocument which I wasn't too worried about so I removed it (I can restore it later should I need it). Sure enough, no the Minolta page loads absolutely find on my internet explorer. You may have to remove more than one entry as the next paragraph will explain why I think this is occuring.
I *think* that the "Accept:" line is too long and the built-in web server doesn't like it. That's my guess. I can remove ANY application/ and suddenly it works. I was easily able to remove 1, if this is an issue with a line problem you may have to remote more than 1 accepted-document. I don't recommend removing any image formats!!!! Also, like I say, backup that key first.
I hope this helps,
Shawn
