It is
possible that the machine does not start off the cycle because there are errors
due to feedback from the inputs. For the program to start up the main program
controller must initiate the INLET/MOTOR/DRAIN
pump/ valve to open up and allow each function to be driven starting from
the flow of water into the drum as also the drain valve to open to exit the
water at the point of the program cycle. If this does not happen then the
voltage at the valve/motor/pump must be checked or the fault relates to no
voltage from the controller. This means
the controller is a suspect. If the
water flows though the inlet then the flow pressure should be good, if not the
inlet valve is bad or there is dirt in the filter. Also check the flow at the
inlet of the water line. Once the water comes into the system the WATER LEVEL
SENSOR - normally a pressure switch- must activate at the preset/chosen level
to give the signal to the program controller to switch on the motor. What is
most important for the motor to start functioning is that the door switch must
be ON when the door is shut or this will be an error for starting the motor for
rinse and wash. Test a
pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8 Check this
link to replace the inlet valve:
SOURCE: My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
SOURCE: Maytag heavy duty super capacity
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
SOURCE: Water fill level switch stops
https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208180895.pdf
hello chris, my name is Mike. You're in luck because this should be a fairly easy fix. Above is a link from the whirlpool website that shows the parts for your washer. If you scroll down to about page 3, you'll see a horizontal rectangular piece that is part of the console. Part number 12 is your water level switch.
This switch is easy to see if you remove the console of your washer, it has a clear plastic tube connected to it. This tube has air in it, and is connected to the lower portion of your outer tube. As the water fills, more air enters the tube (increasing pressure), and tells the washer when to quit filling per say.
You need to inspect the tubing from top to bottom to make sure there are no kinks, or a lot of the times it has just come loose from the switch, or tub. If it has you can reconnect it and retest the washer.
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. Can also cause overfilling.
If everything is connected, there's no water in the tube, then the switch is more than likely just bad and needs to be replaced.
Chris, if you are unsure and you want to test it to be sure, just contact me anytime. My email is [email protected]
You will need a Volt ohm meter or a continuity tester to actually test the switch to MAKE SURE that it's bad. I can almost tell you with certainty that it is though.
Feel free to contact me anytime, and I'll be more than happy to help you out.
thanks
Mike
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
SOURCE: i am looking for a Manual instructions for
Go to this link http://manuals.appliancesonline.com.au/wa75t65gw1/wa75t65gw1_user_guide.pdf and Printer your manual
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
