It keeps running. I press on and off but it just keeps on and on. Originally, it told me I needed more rinse finisher - I added it but the error message continued. It appears that the dishes are clean but I keep getting the error message and the dishwasher keeps running (almost 24 hrs., now!!!)
Had the same problem.
there is water in the base of the machine, and all that is happening now is the pump to drain the machine is working. If you can manage this next bit physically, the quick temporary solution is to turn the machine off at the mains, empty the machine of contents, and in my case, I had to pull the machine out, and drain the machine by tipping it about 45 degrees by lifting the front of the machine. The water will drain out the back of the machine ( I managed to place some cardboard underneath the machine to soak it up) and once drained of the small amount of water, let the machine go level again.
when I turned the machine back on, it functioned normally again for a while.
eventually had to call in a repairman, as it continued to malfunction every couple of weeks. In my case his initial diagnosis of a split container was wrong, and after he took the left hand side of the dishwashing machine off, he has found that the hard water has clogged a component which needs replacing.
i got the quick fix method on YouTube, either by typing the E15 Bosch dishwasher fault on google, or going directly to you tube.
SOURCE: Our Bosch SHU43C Built-in Dishwasher sticks in the drying cycle.
I have the same dishwasher and started experiencing the same problem last week. It is now fixed (at least for the moment). Here's what I did first. I checked the drain pan under the machine for water(none), the heater for continuity(okay), the float for binding(none), and the float switch for proper functioning(okay). I tried turning the ckt breaker off for a couple of hours to see if that would reset the control module(no effect). I then dissasembled the front door and removed the control module. I had previously read about the common problem of a cold solder joint on the heater relay pin on the control board. My heater was working and the joint looked good but I resoldered it anyway. I reassembled everything and it worked perfectly! My conclusion is that it was either a cold solder joint that was somehow causing the problem or a connector issue that got resolved during my disassembly/reassembly. Hope this helps.
SOURCE: Bosch built in dishwasher shu4302uc
There is a recall on the control board of many of these models. I have written a guide to help. It is here. Look for the phone number near the top.
SOURCE: Bosch SHX33A runs continuously. Never finishes cycle.
I have a guide here to walk you through the process of clearing the drain system. You most likely have a clog somewhere and the dishwasher can't proceed because it would cause it to flood.
SOURCE: maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Hi.
E15 error is a flooding error in the base pan. It can be as simple as to much washing powder to a leaking wash pump or sump hose. Tilt the dishwasher back on angle of about 20 degrees and watch the water fall onto the floor. This will allow the dishwasher to run properly again. Monitor the soap powder by putting less in. If it still happens again then there is a leak somewhere and requires further diagnosing.
Cheers
