Wifi is on but will not load any web page
Is your ADSL correctly set up for WIFI?
Have you got the encryption (WEP?) key to enter into the T101? Your ADSL will not connect unless the identical key stored in your ADSL parameter set are correctly entered from the 'keyboard' on the T101.
If you go into T101 Wi-Fi settings, you will see a list of networks, one of those should be yours, just connect to it.
Hope that is of some help, or just a pointer in the direction you want to go. -Good luck!!
Sorry, - should read T101! (Flip of the singers!).
SOURCE: How do you restor you
The easiest way to restore the Cruz Reader to factory defaults is to update to the newest firmware which can be downloaded from here. The instructions for doing the upgrade are also explained on the link above.
This will revert everything back to original condition leaving any information on the internal and external memory cards intact. If you are looking to clear those as well you can do so by formatting the cards by going to Settings->Storage (might say SD card)->Unmount->Format. You can also take the cards out and put them in your computer and use the computer to format them.
The process is pretty of upgrading the firmware is pretty simple even though it might be intimidating. Let me know if you have any more questions
Hope this helps
Ray
SOURCE: Just bought a cruz reader
Before you can communicate with your computer you must run CruzSync from the desktop. There are some driver files that must be sent from cruz to point the way to the reader. After you do this it should connect every time. Some time you will have to pull the USB out and put it back end, especially if the reader or the computer has just woke up from a sleep or hibernation mode. ZumoDrive is the account you must set up when you click or press on CruzSync to make all of this happen. Hope this helps
SOURCE: My cruz reader opens to
it is happening to me too, but on the android. and it skips and then goes back to the android, help me pleaseeeeeeeeeeee!
SOURCE: My Android Cruz Reader R101
This sounds similar to something that happened when I tried rooting my android phone. If it's the same thing, that means you will need to go to recovery mode and install an update.zip package that you can find somewhere online for it. It's because the code for what's supposed to happen after that screen is overwritten and it doesn't know where to go.
SOURCE: My Velocity Micro Cruz Reader
press power button in for about 6/7 seconds then start again,should reset.Otherwise corrupted installation ,,re-installl OS.
