Apple iPod touch Logo
Posted on Feb 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ipod touch will not play in shuffle mode plays a couple of tracks then stops
Iso 6.1
Brian Sullivan
Level 3:
  • Apple Master 27,725 Answers
  • Posted on Feb 11, 2013
Brian Sullivan
Apple Master
Level 3:
Answers
27725
Questions
Helped
5665933
Points
79191
You might have reset to shuffle again
The iPod's shuffle feature lets you randomize playback of albums, songs or even your entire music library. You may also find this feature useful if you want to listen to forgotten tracks in your library or discover songs you haven't listened to yet. Disabling the shuffle feature will return playback of a song list to its standard consecutive order. You can enable and disable the shuffle feature at any time.
Navigate to the main menu. Select "Settings." Scroll to the "Shuffle" option. Select "Songs" or "Albums." If you select "Songs," the iPod Classic will shuffle the songs on whatever song list you listen to. If you select "Albums," the iPod Classic will play all songs of an album you select in order and then randomly select another album. Navigate to the playlist or album to which you want to listen. Play a song to initiate the shuffle. b> iPod Nano and iPod Touch Tap the "Songs" icon on your nano home screen. If you are using an iPod Touch, open the "iPod" application. Navigate to the song list, playlist or album you want to play. Tap the "Shuffle" icon at the top of the list to activate the feature.
Testimonial: "Thanks a lot for your help"
  • Brian Sullivan
    Brian Sullivan Feb 11, 2013
    thanks for replying with good news hope it all works out
5 Related Answers
Anonymous
  • 143 Answers
  • Posted on Dec 17, 2007
SOURCE: IPOD SHUFFLE NOT PLAYING MUSIC
green - orange 2sec
indicates that there is NO MUSIC on the Ipod.
go into itunes, connect your ipod.
when your Ipod connects you will see it apear in the left columb.
click on it. - if your library is now blank there is no music on it.
click 'autofill' at the botom to put songs from your album on to your ipod.
Anonymous
  • 19 Answers
  • Posted on Jan 24, 2008
SOURCE: WHERE TO DOWNLOAD FIRMWARE FOR IPOD SHUFFLE
Try setting a partition in hard drive management then formatting it to FAT32, since you might have formatted to NTFS
Anonymous
  • Posted on Feb 19, 2008
SOURCE: WON'T STOP SCROLLING
i want solution
SmartAviator
SmartAviator
  • 1124 Answers
  • Posted on Jul 15, 2009
SOURCE: no sound through headphones in ipod shuffle.
Player may require formatting. Try after formatting.
Anonymous
  • 74 Answers
  • Posted on Jul 23, 2009
SOURCE: Shuffle does not play all songs
maybe thats because your uploading it from another source that doesnt always work out the way it supposed to be
6th gen. nano has shuffle issues. plays same song over and over
1helpful
2answers
My ipod touch keeps skipping songs
Your ipod touch is on shuffle. To take your shuffle off there should be a shuffle button at the bottom , by your music list.
1helpful
IPod classic stopped shuffling this weekend. I've had it for several months and it's worked just fine, but all of the sudden it stopped shuffling songs within playlists that were set to shuffle. ...
Hey press the play pause button and the enter button at the same time if it has a lock move it baca and forte 6 times while holding play pause button and enter/centered button for 6 seconds, that should solve from freezing ipods to non functioning well :)
Hi My Ipod touch won't 'shuffle' and continuouasly plays the same chosen track. Will I have to restore it
On the track click on the screen at the top left under the timelinethere is a symbol of two arrows in a circle by touching the symbol you change whether a track is repeated or not
My itouch skips songs while it's on shuffle
All ipod devices track how many plays each song has. When in shuffle mode, the songs with more plays are in turned played more often. This can result in some songs playing multiple times while others are skipped;
//halfs
2answers
FIND AN OPTION ON THE IPOD THAT WHEN YOU SHUFFLE SONGS, IT'LL ONLY PLAY IT ONCE. i'm sure there is an option there on the audio options,.
My itouch keeps skipping songs. with each restore different tracks skip. as soon as I fix on track a different one stops working.
when you go to your music file and play a selected song. you will see two arrows in a circular formation and antoher set of arrows intersecting one another (shuffle). change the colour so both sets of arrows are grey by touching them.
18helpful
Ipod touch keeps repeating songs on all playlists
when you are playing a track holding the iPod Upright on the Left hand side under the Track Time there is a Symbol with two arrows in a circle. If this is Blue you are on Repeat All, Blue with a 1 is repeat Track. You want it to be White. On the Right is Shuffle. Good Luck!
3helpful
Cannot stop shuffling
You need to go into your Play Mode ssettings and select "Repeat All" to turn off this feature:
Play mode
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
Ipod tracks in random order
TURN OF YOUR SHUFFLE MODE BY GOING TO SETTINGS AND THEN IPOD AND SHUFFLE TURN OFF.
FOR ANYMORE INFO GO TO APPLE.COM/SUPPORT
THANK YOU APPLE GENIUS BAR
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
