GPS Logo
Posted on Feb 11, 2013
I need a usb cord to be able to update the mapping on an n188 gps navman device . where can i get one and how much do they cost
I could not find the website to order this cord
How do I update my maps on Navman model No. N188
There is a youtube video with instructions on how to do it. The link is:
https://www.youtube.com/watch?v=pdm8y1wFSio
Feb 24, 2015 • Navman GPS
Hi there, i need the original files of the navman
Check online type in name and serial number
Sep 22, 2013 • Navman F15
1helpful
How do i upgrade my navman sat nav with new roads and it used to warn me when speed cameras were present but does not now
Map updates are usually NOT free. Some manufacturers allow for a "one time update" within 30 days of purchase - to ensure the owner of the latest maps. Other than that, there are three models out there.
One is a the purchase of individual map sets for the geographical area of interest for a modest fee. nearly all manufacturers offer this type of update. In return, a disk containing a program to update the maps in the GPS is run on your computer while the GPS is connected via USB cable or serial cable. You might even end up maps preloaded on a removable memory card. Simply inserting the card into the slot on some GPS units will allow the the GPS to use the new maps on the card instead of those installed on the internal memory of the GPS (if the memory card is removed, the GPS uses the old internal maps).
The second model is a map subscription service (Garmin and a few others) that allows for the download of new mapsets as they become available (2 or more times per year) to your computer. This is done on older models (those sold before lifetime maps were offered) or if it is determined that buying updates one at a time will be too costly, after purchasing the GPS. Running the download with the GPS connected to the computer will update the internal maps of the GPS - just like the disk method. The subscription service costs more than buying a single update disk, but is often less than the cost of 2 update purchases. The subscription lasts a predetermined amount of time, or in many cases, "for the life of the GPS".
The last is similar to the subscription method above, only that you purchase the GPS with lifetime map subscription built in to the cost of the GPS. Included in the GPS package are instructions on how to go about starting the subscription and installing the maps - the same instructions are included with the purchase of a subscription after purchasing the GPS.
One place that sells maps for the Navman brand GPS can be found at http://www.activegps.co.uk/navman-maps.htm You may also find them available for sale in retail outlets that sell the Navman GPS devices, too.
Speed or "Safety" cameras and Red Light Camera locations are often offered as a subscription, due to the not necessarily permanent placement of these devices. Some manufacturers offer this, while others do not. Third party providers have stepped up to fill the void created by those that do not offer this information. I found these sites that have this data available:
http://www.pocketgpsworld.com/uksafetycameras-navman.php
http://www.speedcamerasuk.com/speed-camera-database.htm
There may be others that cost less or are even free. Keep in mind that maintaining this database can be difficult, so the free databases are more likely to have erroneous information in them when compared to those databases that charge for access.
I hope this was a good starting pint for you and helped. Please rate my reply - thanks!
Jun 30, 2011 • GPS
2helpful
I want to update my model how do I do it and how much will it cost
Depends on what you mean by update. If you want to exchange your unit for a newer model, that is between you and the dearler/seller.
If you mean that you want to update the software in your unit to more updated maps, then do this:
Go to this site, and select your model, then choose update maps. You will likely have to download the maps file to your computer, then transfer then to your device. Instructions should be on the Navman website.
http://www.navman.com
good luck and don't forget to vote!!!
4helpful
Need to update the maps on my navman iCN - 510 sat nav for free
Go to the home page and use your USB cord and sign in and you should be able to update.
How do i update my maps in my navmaniCN 320
HAVE YOU TRIED WWW.GARMIN.COM FOR YOUR MODEL? IF LISTED CONNECT WITH MINI USB LEAD AND FOLLOW INTRUCTIONS
86helpful
3answers
I need to update my map on navman n40i how can i do it
im after free map updates for navman n40i can you help me
5helpful
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
