I have Print Shop Version 6 that I used on my old computer and LOVED it but now that I have 64 bit Windows 7 the program will not install. I see a lot of people asking the same question about how to make this program work but none of the answers I've found so far have worked. Every time I click on SETUP I get a message that it cannot start up or run due to incompatibility with 64-bit versions of Windows. I've tried running in compatibility mode, tried downloading .net 1.1, tried every suggestion I could find but no change. I know it's an old program, but there should be SOME way of making it work! Please help!
SOURCE: I have a new computer
There is no patch, you will either have to purchase the upgrade to 23.1 or you will have to install XP Mode (directly from Microsoft) and in it to install your program.
http://www.microsoft.com/windows/virtual-pc/download.aspx
SOURCE: recently purchased print shop deluxe version 23.
you can crack the software if it ask for original cd. You can download crack of any softwares from http://serials.ws
SOURCE: I have the full version
Print Shop 22 Deluxe is not compatible with Win 7 (x86 or x64bit) Operating.
You have to use the Print Shop 22 Deluxe version 23.1 - compatible with Win 7 & Vista.
Hope it helps.
SOURCE: I cracked my install cd
Hi,I looked into this for you and listed below you'll find all you need to get a replacement disk,hope I've helped......
If the 90-day warranty has passed and you wish to receive a replacement, please provide the following mandatory items
1. A personal check or money order for $10.95(USD) per disc requested.
2. The disk containing the defect.
3. A letter or card with your full name and return mailing address
4. A reason for the replacement request
Please send these items to the following address. We recommend you send your return via a traceable method such as Priority Mail®, UPS™ or FedEx® as Encore is not responsible for undelivered or lost packages. Please note that Encore is not responsible for the shipping cost to return the product.
Encore Software Inc.
999 N. Sepulveda Blvd
Suite 700
El Segundo, CA 90245
ATTN: Disc Replacement
From the day it arrives it will take 4-6 weeks for you to receive the replacement. If we do not have the product in stock, your check or money order (if submitted) will be returned.
Good luck....
Down load virtual machine free on line. Load XP on Windows 7 on virtual machine and you will be able to use all of your old soft ware.
