Question about Yamaha HTR-6130 Receiver
Sound problem with Yamaha HTR-6130 AV reciever
New out of box. When I watch a movie the sound shuts off for a split second and comes back on, this happens several times during a movie. I checked that all speakers are wired properly. The reciever is connected to a projector via. a digital coaxial audio cable which i have replaced thinking that it was a bad cable. Any ideas as to what my problem might be?
    Top Expert:
  • Yamaha Master
  • 53,029 Answers
The audio may be cranked up too high.
Posted on Sep 22, 2017
SOURCE:
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
  • 6 Answers
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Posted on Feb 16, 2009
mlapres
  • 757 Answers
SOURCE: yamaha HTR -6130 DTS?????
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
Posted on May 08, 2009
smarthome2
  • 1114 Answers
SOURCE: trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
Posted on May 24, 2009
Hi, I have a Yamaha HTR - 6130 that seems O.K. until loud action scenes & explosions,then it shuts itself off.
There are two causes for this. One that there is a fault on the amp that is causing an overload circuit to trip and shut itself down. Or the settings of your speakers levels are wrong. So you are turning it up to hear the quiet parts of movies and therefore when louder sections come along your are driving the amp too much.
Some DVD discs that have THX on them have a sound set up on them. If you have one access the THX sound menu on the disc and adjust your speakers to produce the correct levels. If it does happen after that there's a fault.
By the way most of the George Lucas films (Star Wars) will have THX on them.
Aug 05, 2013 | Yamaha HTR-6130 Receiver
Need HTR-6130 Manual.
The manual is available as a pdf file from yamaha directly at http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-6130_black__u/?mode=model
Midway down under the "support" tab.
May 29, 2011 | Yamaha HTR-6130 Receiver
No picture with Yamaha 6130 reciever. have
The TV must be tuned to the correct input also. Please cycle through the tv inputs by pressing the input button on the tv one time, then wait 5 to 10 seconds for the tv to recognize the input signal. If nothing, press again. You don't say which tv you have but many newer models have 5 to 7 input sources you will have to cycle through to find your signal.
With out more information, this is just one step in finding out what could be wrong. Please rank me accordingly.
Good luck.
Feb 28, 2010 | Yamaha HTR-6130 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
Different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
Jan 08, 2009 | Yamaha RX-V461 AV Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
Dec 30, 2008 | Yamaha HTR-6130 Receiver
No sound from the speakers when we use DVD or XBox
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Getting Audio to work with our Cable Tv
The HTR-6130 does not decode the audio from the HDMI inputs. It only acts as a switcher. You will need a separate audio connection from the cable box to the HTR-6130.
Dec 27, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
203 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
