Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This
is use to reheat dinner plates and left overs. Be sure that you do not
use any plastic foam or metal plates/utensils this can cause damage to
the unit and may cause injury.
Auto Defrost: This
is used to defrost food by weight and type. EX: If you have 1 pound of
chicken, meat or fish press in the food code by using 1,2,3 and then the
weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This
is use with the Rapid defrosting method for 1.0 pound frozen food. If
you have a pound of meat, chicken or fish press Quick Frost and it will
defrost for that weight only.
Cook Time: This
is to set the cook time for the food you are trying to heat or cook.
Enter the time you wish to cook and press enter/start (EX: 7mins and 30
secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This
feature is to add time to the cooking time only in ten second
intervals. If you want to add time without restarting press this button
to add ten seconds each time it is pressed.
Less: This
is used to decrease the cooking time by ten second intervals. If you
want to decrease time without restarting the time press this to decrease
cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This
is use to choose the power level in which to cook or heat food or
beverages. To change the default setting of 100%, press the power level
button and press the level you desire, if you desire only 50% then press
power level the 5 and enter/start. Hint: Change the Power level before
entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This
controls the light on the bottom of the unit if you have a mounted
range above your stove or under your top counter cabinets.
Hot Water: This
is used to heat water for beverages such as coffee and hot chocolate.
Use Extreme caution when removing baverages from your unit, they will be
hot and could cause injury.
Popcorn: This
is used to pop popping corn, when placing the popcorn in the microwave
press the this feature and enter/start and it will automatically start
the correct time for cooking. This feature is designed for the
individual packaged popcorn use. Do not place any foil or loose popcorn
in the unit this could cause damage or injury.
Kids Meals: This
is used to REHEAT meals for children it works at a lower power level.
This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not
place any metal objects or objects than can melt this can cause damage
or injury.
Warm Hold: This
is to keep foods or drinks warm for any length of time up to 99 minutes
and 99 seconds. Although it is not a recommended to run a unit at the
maxium time limit.
Melt: This
is used to melt butter, margarine, chocolate, cheese and marshmallows.
Do not leave these items unattended during the duration of melting time
to prevent any unwanted over heating.
Soften: This
is used to soften ice cream, butter, cream cheese, and frozen drinks.
Do not place anything in a container that is made of foam or metal this
can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This
is the handle or button on the front of the unit to open the unit after
the unit is done cooking or in use. Do not open the door during the
use, always press the Stop/Clear button first. Also do not remove hot
items without oven mits or waiting time food is at a safe handling
temperature.
