Question about Pelican Cobra TT Racing (6770936FA)
How to adjust sensitivity on Cobra TT steering whel
I don't have the manual, and don't know how to set the sensitivity on my wheel, please help
SOURCE:
Tip
Need For Speed Shift Keyboard tips
For anyone who uses keyboard in playing NFS Shift try one these settings.
Steering Dead Zone-15%
Accel Dead Zone-10%
Brake Dead Zone-10%
Steering sensitivity-5%
Acell Sensitivity -5%
Brake sensitivity-5%
Speed steering Sensitivity 100%
Steering Dead Zone: 50%
Accelerator Dead Zone: 25%
Brake Dead Zone: 5%
Clutch Dead Zone: 10%
Steering Sensitivity: 100%
Acceleration Sensitivity: 40%
Braking Sensitivity: 50%
Clutch Sensitivity: 40%
Speed Steering Sensitivity: 0%
Inverse Shifting: Off
Camera Y Axis: Normal
AI Difficulty: Medium
Handling Model: Normal
Steering Assist: Low
Braking Assist: Off
Anti-Lcok Brakes: On
Traction Control: Low
Stability Control: On
Damage Effects: Full
Gears: Automatic or Manual
At least anyone can now enjoy the game without having the hassle of wheels and other devices cluttering up their desk.
These settings work well in the new 1.02 Patch hope these helps.
on Dec 15, 2009 | Video Game Consoles & Games
I don't know how to set up my joy tech nitro steering wheel for Xbox 360.
Just go through to Manual book came with Nitro Steering wheel for Xbox and connect the appropriate wire and cables.
thanks
Mar 18, 2013 | Video Game Consoles & Games
I plugged in the Pelican Cobra TT Racing to my PS 2 (Cars Game) and the buttons and pedals work but not the steering motion. Help?
It could be the game not being compatible with the wheel, but it could be the wheel too. Ask the friend you got it from which games he played with it and see if you can borrow that game. Test it with that game to see if it works. If so, the Cars game is not compatible with the wheel. If this is not the case, the wheel is faulty. You can try to clean it by disassembling it and cleaning it from the inside, but many analog controllers can break pretty easily, and if that's the problem, the wheel is pretty much dead. I hope that the Cars game is not compatible.
May 21, 2012 | Pelican Cobra TT Racing (6770936FA)
My lawn tractor pulls to the right when driving can i fix this?
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Jun 12, 2011 | Garden
Own a 2003 Mustang Cobra, need to know where to look to be able to adjust the clutch assembly, thanks!
If it's a stock set up you adjust the clutch by lifting the clutch pedal up.
The instructions are in your owners manual or if you don't have it go to this Ford website to view or download it for free.
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Sep 17, 2010 | 2003 Ford Mustang
My sensitivity on my Pelican PL624 Cobra TT is bad how do i change that?
i'm sorry to say but even on max sensitivity this wheel is very unresponsive. i suggest you just save up and buy a higher quality wheel
Feb 28, 2009 | Pelican Cobra TT Racing (6770936FA)
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Pelican Cobra TT Racing (6770936FA) Logo
109 people viewed this question
Top Pelican Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
