My truck turns over, but only stays running for a couple of seconds. It may take 20 or 30 "tries' before it stays on...Sometimes it just dies altogether while I am driving. Any ideas
my 89 mazda b2200 has an electrical problem the tail light wont come on when i turn the lights on my 89 mazda b2200 has an electrical problem the tail light wont come on when i turn the lights on
You can't post conmments that contain an email address.
Re: 1989 Mazda b2200 starts but won't stay running
My mazda b2200 starts and will stay running as long as the key is in the start position, but stops as soon as the key is turned from the start position
installed new fuel pump and filter in 97 cavalier 2.2 the car will run for a couple seconds and shut off if you spary it with starting fluid it will stay running
check tail & park light circuits for short to ground. best place to start is at trailer wiring harness. (if equiped) i might want to purchase a "short finder" tool. (fairly cheap at harbor freight.) to help locate area of short. good luck.
i have a 1988 mazda b2200 and i was sittin still runnin and it was a lil low in water and i was just ab to take off when it cut off. it made steam *** out the hood. the thing is its gettin eletric to the plugs and its gettin gas and i even tried a lil eather and its turnin over it just want crank. do u have a idea wat it could b? im thinkin it jump timeing.
When you turn the key to the on position can you hear the fuel pump turn on? If not, the fuel pump relay has gone bad. Make sure you have at least 5 gallons of fuel in the tank. Check and make sure you have fuel flow to the rail, try cracking the banjo bolt on the fuel rail.
Many cars these days are equipped with an immobilizer. (you can find more information about the immobilizer in your owner's manual). The immobilizer allows the engine to run only if the correct key is used. If your car has an immobilizer, you probable see a "Security" or Key-shaped light coming on on the dashboard every time you turn the ignition ON. If this light is flashing when you turn the ignition ON, it could mean that there is some problem with an immobilizer or the system does not recognize the key. If the immobilizer doesn't recognize the key, the engine wold not start at all, or would start and then die in few seconds. You can try a spare key, if it won't work, your dealer is the place to call. Sometimes, the key is just need to be reprogrammed. On some cars you can find the information how to reprogram the key in the owner's manual.
