Machine goes through the washing programme then with 20 mins aprox left it will stop. The error code FH flashes on the top panel and nothing else happens
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
F18
whirlpool AWO3761 fault code FH after 10 minutes of cycle then machine stops
Whirlpool awm8113 displays FH code but water feed to machine ok
