How adjust the phase, level and cutoff in sub 200 woofer
SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel
sound from just one speaker. Simply hook up both the left and the right
channels to the special terminals on the speaker. Hook up one channel
only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
SOURCE: sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
SOURCE: my jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
SOURCE: I have bought JAMO sub 250 subwoofer and Pioneer
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
