Windows media player won't burn music anymore to disk
I first pushed on "Burn"
Then I get command to drag items to burn, which I did.
I inserted blank disk and pressed commmand to start burn as prompted
It rejected disk and open door to drive.. I used another disk. same
result.
I think the program is corrupt and do not know how to fix it. I am
using windows Vista upgrade( windows XP plus Vista)
Has anybody any idea how to solve my problem??
Windows player works all right insofar as loading and playing music,
but I cannot burn.
How do I burn??
Only way to fix in Vista is to reinstall Vista.
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
APPLIES TOWindows Vista Ultimate
Windows Vista Starter
Windows Vista Home Premium
Windows Vista Home Basic
Windows Vista Enterprise
Windows Vista Business 64-bit Edition
Windows Vista Ultimate 64-bit Edition
Windows Vista Home Premium 64-bit Edition
Windows Vista Home Basic 64-bit Edition
Windows Vista Enterprise 64-bit Edition
After you install Windows Vista on a computer that uses an SiI Parallel Advanced Technology Attachment (PATA) chip from Silicon Image, the computer does not recognize an attached optical drive as a drive that supports recording. Therefore, you cannot use the computer to burn CDs or DVDs.
This problem occurs because the SCSIport driver does not populate the correct number of bytes for an IOCTL_STORAGE_QUERY_PROPERTY Request Packet (IRP) when the device does not return a correct serial number.
Service pack information
loadTOCNode(2, 'resolution');
To resolve this problem, obtain the latest service pack for Windows Vista or download the following Hotfix.
Microsoft Hotfix http://www.microsoft.com/downloads/detai...
Please rate this a fixya
Hope this helps
There are tons of other applications available for free that you can use to burn with in the meantime!
http://cdburnerxp.se/
http://www.nch.com.au/burn/index.html
http://www.deepburner.com/?r=download
If you want to try and fix Media Player, I would first uninstall it from add/remove programs first (if possible) then reinstall it by running Microsoft Updates. If you can't uninstall it from Add/Remove Programs, just try running Microsoft Updates - there may be an update to Media Player available that you're missing.
Fix does not apply to my system. thanks anyways. intelligent reply
