Connected computer via svga/component cable to TV resolution bad multiple images and rolling screen
Model= MS-7142, Type=X86-based pc, Bios date=4/24/2006
Running Window XP Home,
TV= Sony 60" LCD Projection TV HDTV
I am getting bunch of small images on TV with rolling lines. I get this in windows and also in the bios/start up area of computer on start up before it loads windows.
Is there somthing in the bios / boot up area that needs changed, or am I just out of luck trying to hook computer to my TV?
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
I have several DVRs, and have had similiar problems. I would first plug the DVR into a monitor and make sure it works. If so, then while you can see the menu, change the resolution.
Look for a button on the remote or the TV itself labeled Source or Input. This should let you change the input between TV, AV, HDMI (on some TVs), and PC. Just press the button repeatedly or use the up/down arrows.
Before setting the input to PC (VGA), turn off the TV and the computer. Then connect the VGA cable (M-M) and the audio cable (a 3.5 mm M/M cable, if you plan to use the TV speakers) between the two units. Next turn on the TV and set the input to VGA. Then turn on the computer. (This is if you are using the VGA or D Sub 15 connection.) For a desktop, if you do not have another monitor connected, the TV should automatically be detected and the resolution set with any Windows OS (XP and later). However, you may need to reset the resolution and the refresh rate. For Windows 7, right click on the display and choose Screen Resolution.
For a laptop, you may need to enable the video port in the BIOS. Accessing this depends on the manufacturer of the computer motherboard. (Often Esc, F1 or F2 is the key to press after turning on the computer but before the OS loads. This can be tricky to time correctly.)
With a laptop or a desktop with another monitor attached, you will need to tell the computer how to deal with the multiple monitors. (Extend, monitor 1 only (or laptop internal monitor), monitor 2 only (external monitor), or dual display.) For my HP laptop with Win7, I choose Graphics Properties instead of Screen Resolution. There may be a keyboard Fn shortcut to access this.
Some TVs will accept a PC signal on the HDMI port (directly from an HDMI port on the computer or via a DVI to HDMI cable). Not all TVs do this. (Without the model for your TV, I can't confirm if this will work. If it doesn't, it is because of the differences between the PC output signal and that of set top boxes (cable or blu-ray players).
Tries go into the computer Control panel go to monitor resolution change it lower resolution like 1020 to 800 should solved ur video problems,scrambling video is tv not supporting the current resolutions.
Determine what kind of video line-in connection the TV has. These connections are typically on the back or side of the TV. You also will need to determine what kind of video line-out connection the computer has.
Types of video connections include S-Video, VGA, DVI and HDMI. The Resources section of this article offers links to sites that will help you identify the connection type of your TV and computer.
Purchase a video connection cable that is for the type of connection that the computer and TV share. For example, if the TV and computer both have S-Video ports, you should purchase an S-Video cable. S-Video connections are the most common and least expensive option.
Connect the end of the S-Video cable that matches the connection on the computer to the computer video line-out port. Connect the other end to the video line-in port of the same kind on the TV.
Convert video from VGA video to S-Video or even component video. Do this if the two connection ports on the computer and TV are not compatible. You will need to purchase a scan converter box, a VGA video cable, and either an S-Video or component video cable. Connect the cable that will connect to the computer jack to the computer and the converter box, and connect the S-Video or component video cable to the TV and the converter box.
5
Turn on the TV and use the remote control to select "Input." Some TVs will have multiple selections. Turn on the computer and play a movie or display an image on the screen. As you are scrolling through the "Input" options on the television, you will see a matching image of what you opened on your computer on the TV screen when the correct input is selected.
6
Adjust the screen resolution on the computer if the image on the TV is distorted, too small or too large. Do this by going into Control Panel and Display Settings on the computer. Select a different screen resolution until the image on the TV fits the TV screen
IF, your PC indeed supports TV out, then the Cable usually is SVGA or RCA, connectors. The PC must be configured to activate BOTH screens, ie: enable desktop, to be spanned or mirrored, , the Resolution on TV should only generally be set to 800x600. The correct Drivers must be installed. Must connect to TV before ya start PC too.
For your resolution to come up perfectly, update your graphics driver. Also if your monitor came with a disc. Install the software if any available on it.
Hey smittybd, According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections. If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation. Hope this helps you out. Sincerely, Aaron Go Ahead. Use Us.
Not sure if you have fixed your problem or not. When I hook up my pc to the ILO 32 HD...I ran DVI input for picture...you can also use HDMI if you like..I had a problem with sound and had to use a splitter and run sound into AV2 IN to get sound for some reason...your no picture...if you are getting a black screen, you need to set the resolution on your pc. VGA to 640x480 and SVGA should be 800x600 and XGA should set at 1024x768..most likely the last one is the one you need..and this is not a normal pc res....set your refresh rate to 60HZ. All this is done in the control panel/display/settings tab.
Also remember that you need to change your source on the TV to the proper connection to see it...ie component, HDMI etc.
