Mitsubishi WS-55311 55" Rear Projection Television Logo
Tony Ledford Posted on Feb 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi WS-55311 55 In. Rear Projection Television will power on but won't stay on
Sonny Berry
Level 3:
  • Mitsubishi Master 8,617 Answers
  • Posted on Feb 11, 2013
Sonny Berry
Mitsubishi Master
Level 3:
Answers
8617
Questions
Helped
1721630
Points
23750
When it shuts down have you tried accessing the self diagnosis feature to retreve the error code?If so whats the blink code your getting?
5 Related Answers
A
Anonymous
  • Posted on Jun 08, 2008
SOURCE: Mitsubishi WS-65611
My mitsubishi 65611 is about 4 years old - I am getting a green overlay color on the screen can you advise what this might be?
Anonymous
  • Posted on Feb 22, 2009
SOURCE: Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sparko1
Mark Wakefield
  • 167 Answers
  • Posted on Aug 03, 2009
SOURCE: Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Chi Chu
  • 8457 Answers
  • Posted on Jan 15, 2010
SOURCE: Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
Anonymous
  • 160 Answers
  • Posted on May 07, 2010
SOURCE: WS-65513 65 in. Rear Projection HDTV Television: My 65 inch Mitsubishi tv turns off a couple of sec...
The power supply will need to be replaced.
Won't power on
Check the Mitsubishi TV error codes using the instructions on www.TvRepairKits.com . Look on the tips page. If its a steady blink its likely the blinking light of death issue. If its a 2-2 pattern its likely a convergenec failure. Both are failry easy DIY tv fixes.
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
1helpful
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
1helpful
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
1helpful
My TV won't turn on - it was working fine when I turned it off and now it won't turn on...
have you checked the fuse at the back??...this just might be your problem. It is located on the power supply side of the motherboard.
Good luck and thanks for using Fixya.
G..
My tv won't stay on.I pressed reset and input at same time.it blinks twice and that's it.
You have to press the menu button and the input buttons both in together and hold for 6 seconds then count the two digit blink code and let me know the blink sequence.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
