HI,
I have an Acer Aspire 4520 laptop. I have a weird problem. My battery doesn't charge when the laptop is powered On. But it does when the laptop is shutdown.
When the laptop is shut down, the Battery charging indicator starts glowing orange, even when the power socket has not been connected. When I start my laptop then the LED stops glowing and the battery stops charging.
Please help
Regards,
Deepak
My acer 4520's battery is not holding its charge? what should i do? what voltage should the battery be?
To solve it, you should know where the problem lies, battery, adapter, or laptop? so please try 3 ways,
1. try the battery on other laptop,
2. try to use a new battery on you laptop,
3. change a good adapter.
Replace the battery of lappy
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
thanks for replying. but my battery gets charged when the laptop is
shutdown. Also am not able to power on the laptop without the battery.
So I think its not the problem with battery.
