Canon PowerShot S2 IS Digital Camera Logo
Sondra Graves Posted on Feb 10, 2013
Why won't my Canon PowerShot S2 IS turn on?
The camera was working fine the last time we used it and when we started to take a picture, it wouldn't turn on. We put new batteries in it and it still won't turn on.... it hasn't been dropped or anything, so we have no idea why it won't work. They had the same kind of camera at my husbands work and it stopped working just like ours has. We would like to know if this is something that can be fixed.... and where can we take/send it to be fixed. Also, how much it would cost....
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Feb 12, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
6063
Points
17
Definitly it can fixed... about the cost we have to check and aure the excat problem.
5 Related Answers
Anonymous
  • 46 Answers
  • Posted on Jun 01, 2008
SOURCE: cannon powerShot S2
Unfortunately this issue is most commonly caused by an electrical failure with the camera's power unit. Sometimes a hard reset will work, though I'm not sure if permanently.
Usually the solution is to call Canon's tech support and have the unit sent in for service. To give the reset a try however turn your camera on and immediately press and hold the Menu button for approximately 7 or 8 seconds (until you get a Reset Camera message). If you can get this far, do the reset and then power down the camera.
Then remove the memory card, the batteries and the date/time battery unit (a small rectangular door located inside the main battery well). Once all batteries are removed, turn the camera's power switch into the on position. Wait two minutes then press the power button as if turning it off. Then replace all batteries and the memory card.
Turn the camera back on and immediately set the time and date.
Turn the camera off and on a few times and take a few shots if possible. This works in about 25% of the time. If it doesn't and you have confirmed that the battery itselef is good (by placing it in another unit typically) then the camera will typically have to be sent in for a service repair.
Hope this helps.
Sincerely,
HeavyDLB
Anonymous
  • 3 Answers
  • Posted on May 29, 2009
SOURCE: Cannon PowerShot S2 IS lens is stuck
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
Anonymous
  • 126 Answers
  • Posted on Jul 02, 2009
SOURCE: Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
t00nz
CameraR
  • 4738 Answers
  • Posted on Apr 29, 2010
SOURCE: my Canon S2 IS Powershot camera LCD screen turned black
A stuck shutter is another common failure mode for digital cameras, ESPECIALLY for the S2 IS (you should actually complain to Canon at 1-800-OK-CANON. If it is indeed a sticky shutter, they have been fixing this for free). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Hope this saved you $99.
Anonymous
  • 73 Answers
  • Posted on Jul 26, 2010
SOURCE: Battery low indicator on Canon Powershot A470 camera is always on
You're using alkaline batteries. No matter how much you pay for alkaline type batteries, they just cannot cope with the amount of power that a digital camera needs - especially an older model. Use a type called lithium AA, energiser make a very good version. You can usually buy them in camera shops, and they can be a little pricier, but the camera will take between 300-500 photos per set, so worth it. If thats not possible I would suggest using rechargable batteries with a charger - the higher the number the stronger the battery. 2100mAh to 2900mAh should be okay for a camera, and the best type is niMH (not niCD). Good luck.
2helpful
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Newly charged batteries don't work
try going to canon.com and download the firmware update for your camer, it will work fine after that
Black pictures when using flash
The black images with flash mean that the Iris mechanism in the lens is not working properly, and that needs a professional camera repair service.
Best regards,
Canon S2 is washed out pictures
Just when I thought my camera was fixed I started experiencing the same problem with my S2 IS. Don't know if it is any help to finding the solution but the camera works fine outdoors when used in video mode.
CANON POWERSHOT S2 IS 5 MEGA PIXELS
I bought mine 2 1/2 yrs ago too. Found this solution on this site and tried it. It worked perfectly.
Turn to TV mode, set the exposure to 15 seconds by pushing the little "arrow dial" until you have 15"
Push the button to take the picture.
Wait 7 seconds from when you push the button, then turn over and open the battery door while it is "taking the picture."
Close the battery door and turn back on.
I did this three times and the last time, it worked and the iris became unstuck.
Then I took a million pictures to get the iris moving.
Digital camera
the camera is working , i did what the guy said with turning to tv and 15 and open battery top , it took 5no times working fine ,thanks very much its amazing and unbeleavable im stuck for words , thanks again regards jamie bow th
2answers
Canon S2 problems
Low battery power ? (rechargeables do not last forever).
Try a brand new set of batteries
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
