My canon pixma ip1000 prints,but no image/letters/colors ...blank
I usually used replacement inks, until I used much cheaper from china. First, black , print a little, then colors, then it prints, but no images/letters, I tried cleaning the print head with isopropyl alcohol , no result , then with lukewarm water, then with chlorox . Still, it is printing but paper is blank. I bought a replacement cartridge made in korea, the same I used before the ink made from china, soaked the printhead for two hours in isopropyl alcohol for two hours , dried for an hour, then put the new cartridges, then perform deep cleaning procedures . Still, no printing , I mean it prints, but no images/letters/colors... blank. Can You suggest another way ? Please help me, Thank You.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Based on your explanation I will try to help.
Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
Remove the printer software. And remove the driver from device manager "usb printing support" .and remove printer from control panel>printers, and download latest driver from Internet and install. It will work, if not contact service centers with your printer
Hi vdkmail, Perform nozzle check pattern from maintenance menu in printer driver properties first. Is all black nozzle printed?. Is it perfect or partially printed?. Or no black nozzle printed at all. Then perform printhead cleaning procedure to fix this. If problem still persist means the printhead should be replaced with new one. But be careful, print blank (no nozzle printed at all) might be caused by faulty purge unit too so that ink not flows down from ink tank. Regards,
printer is canon pixma iP 1000. Initially print was not good after
washing the head it does nit print at all. though ink cartiges show
full.
