SOURCE: Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Why is it I feel as if two of you did not read my post? There was no capacitor kit. The warranty repairman in support of the extended warranty put a brand new Power Supply board in the TV. I also tried the 'Menu' and 'Device' combination on the TV, as I also stated, but it's a different day, I'll try it again. As for the power button combination, that's interesting, I'll go play with that right now. I'll also look for the reset switch, I assume you are not referring to the one on the front panel next to the volume controls, if so, I pushed that, it clicks, and it doesn't change anything..but I'll look for the one you are talking about. Not sure where that one could be, but I'll look..Thank you all for your quick responses, I do truly appreciate it!
None of your ideas worked. Leaning towards it being the main board, though I'm not quite sure why the set reset button on the front seems to work, and nothing else does. Seems like that would be connected to the main board somehow, and therefor should not work...don't know, probably need to trace that connection to see where it goes. It almost seems like there is no power from the Power Supply board outwards, but you can hear that energize..like a fuse is out basically. There is quite a few plugs coming off the PS board, so you'd think SOMETHING that it is connected to would work. Maybe it's just a faulty PS Board...possibly need to resolder everything...also tried using a hairdryer on the PCBs..nothing..
The new power supply was made in Mexico... Once I got a close look at the solder joints, I see that it's possible that that cold be the problem. Looks like it was soldered by small children in a preschool. Sloppy... There is extra solder splattered everywhere, cold solder joints, one solder spot that appears broken in two...I don't know. Goin to work on this mess first, and see where it gets me. Y'all keep the suggestions coming. I see 12 experts looked at this and no one had any ideas? At the very least, I will come back on here and be the expert to you when it is done. Deal?
I have the same problem with my tv .. Text me 9035636290 or email me [email protected]
