May 29, 2011 - Navigation map DVD disk read error - Suzuki 2007 XL-7 question. ... The only correction I've seen for this problem is to replace the radio itself. ... Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time ... Navigation system at Yukon xl 2008does not read the map DVD.
The part is called a Din connector. You may be able to find it at www.jvcservice.com You will probably need to use the sub-woofer or the system model #, it is not listed under th-c30
To eject the dvd from the dvd player you have to push the eject button on the dvd player, if the dvd is stuck inside the dvd player you have to get it checked by a service technician
Check your formatting on the DVD recorder, you need to finalize the disk to be playable on "any" player. That should solve the issue. Your JVC is looking for specific code as it reads the disc, when it's missing or not understood by your JVC it will either stop play or skip over it's interperated missing info. Hope this helps
Get a paper clip and unbend it so you have a straight wire. Then look closely at the dvd tray and next to the eject button you will see a tiny hole. Push the paperclip wire into the hole and manually release the dvd tray.
Well all you have to do is Hold down the power button along with eject button on the unit. If this does not do it you have to take apart the unit or have someone service it for you.
