Washing Machines Logo
Posted on Feb 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Duet dispenser problem
The fabric softener and bleach will not dispense properly. They're still in the dispenser after the wash. Both liquid and powder detergent dispense ok. My new Duet was delivered and set up yesterday afternoon. I put in my first load of laundry, filled the dispenser with liquid detergent, liquid fabric softner and bleach. When it was finished, I noticed that nothing smelled fresh. I opened the dispenser and the detergent was gone, but fabric softner and bleach were still in the dispenser! help! On the first load!?
Anonymous
Level 2:
Scholar:
  • Expert 99 Answers
  • Posted on Feb 07, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
99
Questions
0
Helped
35970
Points
170
This is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
1helpful
The soap dispenser works but the bleach and softener dispensers do not
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Soap dispenser not working properly, the fabric softener and the liquid bleach not dispensing properly. Sometimes the softener dispensed as soon as I push start. The bleach not dispensing at all I have...
Don't know where you live, but commonly silt comes up with the cold water supply, especially in rural areas, and clogs the holes in the dispenser. The best way to deal with this is an old toothbrush to rub it clean. When it dispenses some bits too soon, it could be that the water is pushing through the only holes that are available. Give it a good scrub with an old toothbrush and hopefully you will both be smiling :)
2answers
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
1helpful
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Detergent and fabric softener dispense at the same time
Whirlpool has designed this drawer as a siphon feed and soap and softener go as 1, 2 punch followed by bleach mid cycle.
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
17helpful
2answers
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
3answers
Fabric softener leaks out at beginning of wash
I have a 9200SQ Whirlpool duet.  It might be similar.  I think the bleach and fabric dispensers work on the siphon principal--once the level gets above a certain point they will then siphon out until almost nothing is left.  They should not start to siphon until extra water is directed into them during the correct cycle.   It is possible that they are starting to siphon early because 1. the washer is not level, 2. water is being added to the dispenser during the wrong cycle 3.  You put too much liquid into the dispenser and it started the siphon.
Note:  You should not peek in the dispenser during the washer cycles because it might interrupt the "siphon"action and leave residual bleach or fabric softener in the dispensers.
2helpful
3answers
this may be due to a faulty solenoid, if the cold water is flowing into the machine under normal use at the start, then check the solenoids as the conditioner has its own, the solenoids are just behind the body where the water pipes fit to the machine, they have 2 wires on each one, and are tested for circuit when machine is unplugged. stat there, hope i have helped
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
