The door does not seat tightly against the seal at the top of the door leaving a 0.25 in. gap. Hot air from the oven heats the stove valves above the door and they stick or are even inoperable. The door hinge does not seem to be adjustable.
SOURCE: Maytag Gemni Stove
The problem is either in the oven control or the element (in some cases could be both). You will need a meter to check the resistance on the elements as well as power to the element. Remember this is 240 volts and very dangerous. If your not comfortable with it call a professional.
SOURCE: hook up oven door on maytag gas range
You likely need to lock the hinge in open position to do it. Either there is a small lever on the hinge itself you need to flip when the hinge is in the open position or there is a hole in the hinge, where you need to insert a steel pin (you can use screws, but they bend somewhat ;)) to hold the hinge open
