Loose pully on back of motor axle shaft and pully tentioner . Need to take casing off, but don\'t know where to start disassembly to do so. Anyone got any diagrams or books todo so? Thanks
SOURCE: need to know where the
Difficlut to specify as you did not indicate the make or model of your dryer, but usually the tensioner goes into slots on the machine base, and the belt holds the tensioner off of the interrupt/safety switch...
SOURCE: Is there a diagram of how to run the belt on the
Man Im not sure if this info will help you but. On my dryer which is pretty much the old style, standard type dryer and I had to replace the belt and had a little trouble putting it on the tensioner, finally figured it out.. If you take the belt and pinch it together and pull under the belt tensioner and then around the moter shaft that's what you do for the dryer style I have.. HOPE this may HELP!!
SOURCE: Have a Whirlpool electric dryer,
watch this youtube video it will show you at the 1minute23 second mark the exact placement of the idler pulley in the base frame and also how the belt fits on the idler and motor pulleys pause at 1:23 to see where they go http://youtu.be/CFnXwmUb4f4
Good luck
i hope this helps and if it does please give me 4 thumbs up
Gene
SOURCE: I need a diagram of
Hi c ellerts..
Here is the picture of the routing of your Maytag..
You can get this at the following wepage
Please take time to rate me thumbs up
http://www.expertappliance.com/dryerbeltconfiguration.html
